Hey folks...
I got my CDL with all the endorsements last winter. I didn't go to a school for a certificate - I just took several private lessons from a school and took my road test. I worked a seasonal job since April that included 200+ hours running semi's locally. The season is coming to a close soon!
Like everyone else, I have financial responsibilities that need to be maintained.
I have two driving options: local or over the road.
If I drive locally, I will make "full pay" (x amount per hour or whatever) on day one. If I go to work over the road, I know I will have orientation, running with a trainer, etc.
The web sites from national companies are all over the map so if someone can 'generalize' this stuff, it would be most appreciated...
Step One - Orientation
How long is typical orientation and how much does one get paid, if at all?
Step Two - Training
I'm sure I will have to run with a trainer for a while. How long is this usually and how many miles per week and cents per mile is typical?
Step Three - Solo!
If my goal is to run 2,500+ miles per week at whatever best cents per mile rate I can negotiate, I'm sure there is a period where, as the new guy, I won't get the best miles per week or cents per mile. Can I expect many of my first weeks running solo to be under 1,000 miles? Under 1,500 miles? Also, once I go solo is the cents per mile rate the full rate or is there often a discounted rate for the first few months?
On a different note, are there any companies that are amenable to seasonal work? I'd love to be able to work over the winter into the spring over the road and then do my seasonal job again next year and return to the same otr carrier in the fall.
Thanks in advance for any input...
How Long Until I Make Full Pay?
Discussion in 'Questions From New Drivers' started by LI Trucker, Oct 12, 2010.
First off, step one maybe a refresher course. Most companies require that you go to an accredited school for a certain amount of hours. Actually it's the insurance companies that make these rules that the companies have to abide by. Now that doesn't necessarily mean that you can't find a company or O/O that may over look this. I am talking about your general companies. With that being said yeah you will have to go with a trainer too. Usually the time you ride with a trainer is paid by a salary. Probably around $300-400 a week. Don't sweat it though the time will fly by and you will probably have a lot of fun! Chances are you will pick up some info you didn't know of. If you aren't being trained properly or the trainer is just using you for miles then tell someone about what is going on and get a different trainer. One call to safety dept. should do the trick! Once you get your own truck I think in general companies try to get you some good miles right off the bat. For any driver miles a week will vary so don't count on a certain amount of money every week. You could do 4200 one week and 1200 the next! Just make sure you plan for it. There are many drivers that get negative pay checks! Once you have some knowledge and experience you will learn how to stay busy. In trucking you really have to hustle. Welcome to the forum and good luck to you!
LI Trucker Thanks this. -
Dare I ask how someone not an O/O or L/O gets a negative check?
Locally here in Chattanooga, there is an out fit that runs US Mail over the holiday season. Pay is 22.17 an hour.
Look into Mail haulers in your area for a lucritive seasonal position.
Good luck.LI Trucker Thanks this. -
