this might be dumb question but hey im posting it on the newbie section alright!.lol..
i recently bought a truck with a small cobra 12v-120 inverter hooked straight to one of the trucks battery. its got connected a small fridge and a tv, my question is can i leave the fridge on overnight without killing the batteries??
How many of you doing this? or something similar, feel free to share.. Thanks!!!
how many leaving fridge overnight?
Discussion in 'Questions From New Drivers' started by leo319, Oct 3, 2011.
Depends on the draw and how good your batteries are. However, I have a fridge in mine and leave it running all the time, except when I'm on hometime. Never a problem.
batteries look good...i notice when the fridge on, the reader on the inverter moves between 12.1-12.4. is that what youre referring by draw?
its got 4 batteries btw...
My truck would shut down power to non critical systems when the batterys got too low. I've lost some food that way but, my truck would always start. Luckly for me.
I leave mine on all the time. Never a problem.
If you're getting down to 12.1, you're batteries are getting weak. Need to charge up again.
Draw is the amount of wattage you are using. Just as a basic understanding, If a battery is rated for 100 amps, that will give you about 50 amps max you can use. Really 40 is closer to the limit.
40 amps X 12 volts = 480 watts available. If your fridge draws 125 watts per hour contineous, then you will have used up your 'bank' in about 4 hours.
Fridges don't run contineous, batteries have more reserve than 100 amps and you have multiple batteries, but that gives you the analogy. -
less than a year driving experience and you bought a truck congratulations. I really hope you make it as an o/o. As far as the Fridge if your batteries are ok it should be fine for a 10 hour break but any longer i'd unplug and keep the door closed.
OOoh i see... thanks for the explanation emulsified...ill do the math with what i have..
the 12.1 im gettting is what i see on the inverter itself... and that only moves when either i have the tv and fridge on or only one...that makes me think its gotta do with the amount of power im using right? -
It means either your batteries aren't getting fully charged or they are getting old and won't take a full charge anymore.
Should be around 12.8 - 12.9 ten minutes after shutting off the engine. -
alright... ill test them next time im in... thanks again..
@TennMan- thanks, im trying my best.. i figured i should be fine but just thought id ask before i wake up with dead batteries.. gotta check my voltage tho, seems low according to the guy on top
