How many problems can I have and still pass the DOT physical?
Discussion in 'Questions From New Drivers' started by arpta2, Jan 23, 2012.
  1. arpta2
    arpta2 Bobtail Member
    13
    Jan 19, 2012
    Shawano, Wisconsin
    How many things can I have wrong with me and still pass the DOT physical? I am type 2 diabetic but not insulin dependent and my blood sugar levels are good, being controlled with diet and a pill (metformin) twice a day. I have high blood pressure, also controlled with meds. And I have sleep Apnea but use a CPAP machine and an oxygen generator. The good news is that I'll pass a drug test. Is there a point at which they just disqualify you, or can I still get my med card if the conditions are controlled? Thanks, all help is appreciated.
  3. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    You will end up getting a 1 year DOT card, rather than a 2 year card. You should have a doctor's note stating that your BP and diabetes and your sleeping disorder, are under control, should your employer require proof of your condition.
    After that, you're good to go.
    Someone else should confirm what I have just said.
    arpta2 Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I don't see any problems. I would get a letter from my personal doctor stating everything is under control. Get a compliance letter from the RT. Blood pressure tests under 140/90 and you are good to go. Like Gizmo said, it'll most likely be a 1 year card. Good luck!
    I'm curious though. How's your thyroid? I have what you have and after reseaching for a year I found sleep apnea contributes to the package deal of diabetes, BP and hypothyroidism.
    arpta2 Thanks this.
  5. Allow Me.
    10,670
    12,209
    May 28, 2009
    Rancho Mirage, Ca.
    Don't get too excited just yet......one of those conditions, no problem, but 3 conditions ? There are tons of applicants with NO medical conditions, right ? Just start the process and see what happens.
    arpta2 Thanks this.
  6. arpta2
    13
    Jan 19, 2012
    Shawano, Wisconsin
    CondoCruiser,
    Thyroid is good, all my issues are self-inflicted. Too many years of eating good and not exercising. Trying to correct it but it takes time. Feb 1st will be one year without touching a cigarette and down 21lbs. I am going to take some time and lose more weight. Would like to start training at Fox Valley Tech this summer but don't want to waste my time if there is no chance of passing the DOT. So, thanks for the advice.
  7. arpta2
    13
    Jan 19, 2012
    Shawano, Wisconsin
    Are you speaking of passing the test or getting hired?
  8. TennMan
    TennMan Road Train Member
    7,866
    9,658
    Sep 21, 2011
    Hazzard County Jail !!!!!
    dot exams are about 80 dollars spend the money then you'll know if you qualify for a card. thats easiest and most accurate way to find out. I'd say if everything is controlled and DOCUMENTED then you'll pass
    arpta2 Thanks this.
  9. sidewinder429
    sidewinder429 Light Load Member
    68
    32
    Jul 18, 2008
    Getting into a truck can make your medical conditions worse. It takes extra effort to keep those in check and even more to get to a point to reverse them if you are driving truck.
    You may find that yes you can pass the physical but there will be companies that will not hire you and some that will.
    arpta2 Thanks this.
  10. dollarmtn
    dollarmtn Light Load Member
    55
    53
    Sep 7, 2011
    Is there a sample DOT physical form available to view anywhere?
    arpta2 Thanks this.
  11. Bigarmin88
    Bigarmin88 Road Train Member
    1,791
    376
    Aug 30, 2008
    Tampa Bay Fl
    arpta2 Thanks this.
