How much braking is too much
Discussion in 'Questions From New Drivers' started by Chrissholt, Dec 7, 2014.
  1. Chrissholt
    Chrissholt Bobtail Member
    11
    Dec 3, 2014
    when descending down a hill how do you know if your in the right gear? If you're braking with 15-20 psi to keep your rpms low, how often would you expect to apply the brakes if you're in the correct gear?
    lets say for example were going down a medium grade steep hill.
    Im trying to better understand how to drive down a hill and how much I can use my brakes before things go bad.
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    You shouldn't have to use your service brake when descending a grade if you set things up properly. Which means slowing to the correct speed for the grade and the weight of the truck. Slow to a speed that you can maintain with the engine brake on the highest setting. As the grade changes, turn on your engine fan manually to slow down, or select a lower engine brake setting to increase speed.
    ramblingman Thanks this.
  4. Chrissholt
    11
    Dec 3, 2014
    Sorry, I was concerned more about bad weather and not being able to use the engine brake.
  5. OPUS 7
    OPUS 7 Road Train Member
    1,124
    1,010
    Aug 13, 2010
    404
    Its gonna depend on weight,and how your loaded,and
    what kind of grade your going down.
    Of course always do what feels safe for you,but you
    don't want to cook your brakes.
    Focus on the stab braking,and release.If you ever are
    in a situation where the brakes are smoking bad,and you
    make it to the bottom,keep going til brakes cool off.
    I've witnessed first hand drivers pulling over at the bottom,
    and getting brake fires.If you can ride it out,and let em cool
    off you will avoid burning it down.
    As the old saying goes You will only go down a mtn. too fast once.
    "semi" retired Thanks this.
  6. Chrissholt
    11
    Dec 3, 2014
    Not very much weight really so I'm pretty light. I'm just not used to how often and how hard I can use the brakes since most of my driving is pretty flat.
    If im descending Down a steep 1 mile hill and I have to use my brakes every 10 seconds is that too much? How about every 30 seconds?
  7. Hammer166
    7,464
    27,076
    Aug 18, 2007
    ~8600+' and loving it!
    10 seconds is way too often! 30 would be a minimum time, you want the engine doing most of the braking, and the brakes only providing a snub to maintain speed.
    OPUS 7 and Chrissholt Thank this.
  8. Chrissholt
    11
    Dec 3, 2014
  9. Arielit0oo
    Arielit0oo Light Load Member
    187
    108
    Jul 6, 2014
    Tacoma, WA
    You shouldnt have to use your brakes if you're light.. Be in the correct gear, with the Jake brake on and that should be more than enough.
    I barely press the brakes down hill, even fully loaded on a 2mile 6% grade for example. I just let the truck go. I maybe press the service brakes onces, if that.
    All depends on what you feel comfortable with. You should be using the service brakes the least amount possible.
  10. OPUS 7
    1,124
    1,010
    Aug 13, 2010
    404
    That's a dang good Mark Twain quote.That should be on a t-shirt
    Hammer166 Thanks this.
  11. Chrissholt
    11
    Dec 3, 2014
    No engine brake
