How much DEF to add?
Discussion in 'Questions From New Drivers' started by IluvCATS, Jun 5, 2018.
  1. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    Question. Exactly how much of the DEF fuel additive should I be putting in the diesel for best results?
    austinmike, tscottme, ExOTR and 7 others Thank this.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    About 50% is a good rule of thumb.
    Edit.
    I misunderstood. Don't worry about it it's not your truck.
    RedRover, buddyd157, okiedokie and 2 others Thank this.
  4. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    This is dangerous. Some jack ### will folllow your advice. So for you out there that don't know better this is a JOKE.
    I'm going to record this as my monthly mandetory near miss report for my safety department.
  5. okiedokie
    okiedokie Road Train Member
    13,302
    103,414
    Jun 13, 2011
    PNWET
    Had a guy do just that on a job. Mechanic had to drain tanks. You guessed it. FIRED!
    IluvCATS Thanks this.
  6. My-Ke
    My-Ke Light Load Member
    These crack me up.. but these really are dangerous posts. Some poor driver, maybe not even a Swift driver, just a noobie.. might not know what DEF is then GOOGLE "DEF", come across this article, and think they just learned something new. So I'm going to be the downer, and say out loud for the new guys.. DO NOT PUT DEF IN YOUR FUEL TANK. DEF GOES IN THE DEF TANK ONLY!!!
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    It's the same ratio used for the blinker fluid.
  8. tucker
    tucker Road Train Member
    12,647
    40,424
    Jun 13, 2008
    IN
    I’m with you and the other one.
    This thread really should be deleted.
    IluvCATS, Friend and joesmoothdog Thank this.
  9. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    but in an emergency you can pee in the Def tank........ that's when you're in a def jam
    dan31186, Jarhed1964, tscottme and 3 others Thank this.
  10. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i would hope...none.
  11. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    After the fuel shuts off you can top it off the rest of the way with DEF. That's why pumps are setup to pump the fuel first.
    IluvCATS and Oldironfan Thank this.
