How much fuel do you really have left when that fuel light comes on
Discussion in 'Questions From New Drivers' started by DAX_, Mar 5, 2020.
  1. bzinger
    bzinger Road Train Member
    16,613
    65,931
    Dec 10, 2014
    omaha , ne
    2013 cascadia with 100 gallon tanks ..got about 50 gallon left when lite comes on .
    Of course I would never admit this knowledge to my girlfriend who thinks the low fuel lite is normal .
    Brettj3876 Thanks this.
  3. Dax
    Dax Bobtail Member
    8
    15
    Apr 9, 2019
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Haha back in high school i knew exactly how much gas i had left and found the needle would go below the empty line. Or another trick going up a hill in my sonata if the needle moved i still had some lol
    nredfor88 and bzinger Thank this.
  5. MACK E-6
    49,175
    229,303
    On mine I have a 100 gallon and a 50 gallon tank. Yesterday the light came on about 80 miles from the barn. When I fueled it up 41 gallons went in the small tank, and 86 went in the larger one. That’s 3 days worth of running, with a heavy backhaul on Monday.
    PE_T Thanks this.
  6. Lostmykey
    Lostmykey Medium Load Member
    386
    521
    Oct 6, 2019
    I had an over gross load that prevented me from filling up. Shipper refused to fix it cause I scaled barely legal with 3/8ths of a tank.
    Dispatch wouldn’t let me fill up to have an over 80k scale ticket and once shipper knew that, they told me to beat it.
    Company eventually said to just run and let me only fuel enough after scales to get past the next one. Was still limited by our fuel stop choices (loves, ta, Petro). Was a super nervous trip for me.
  7. SmallPackage
    5,511
    17,565
    Dec 20, 2019
    Marion Texas
    9B6DEBAE-5530-491C-8D96-DC2565F9F25F.png B1A56BF8-E43C-45CE-A9B1-98DA9AA0EF8B.png Only Cosmo Kramer and that other guy were brave enough to take it down below the last hash on the gauge
    snowlauncher and gentleroger Thank this.
  8. Moose1958
    Moose1958 Road Train Member
    15,191
    33,481
    Dec 17, 2010
    Williesburg, Virignia
    Just as a side, if I remember my physics correctly, the temperature of the diesel can affect it's density and volume somewhat. I remember a while back some court cases charging truck stop operators saying they heat up the diesel way too much. I wonder if this might also change when this light goes on too!
  9. Numb
    Numb Crusty Curmudgeon
    4,112
    9,529
    Jan 30, 2012
    Charlotte, N.Carolina
    I like to fuel before loading.
    always told them I ain't playing the minimum fuel game.
    kemosabi49, Bean Jr., DAX_ and 2 others Thank this.
  10. Moose1958
    15,191
    33,481
    Dec 17, 2010
    When I got a dispatch that said go in with no more than 1/2 tanks I got angry. I had a bottled water facility to refuse to load me because I had "too much fuel". Stopping every 300 or so miles to fuel is a royal PITA.
    tscottme, Bean Jr. and Numb Thank this.
  11. 25(2)+2
    18,751
    45,534
    Sep 18, 2006
    the road less travelled
    The tanks are set up to draw from and return fuel to the bottom of the tanks, but the pickups aren't always centered, and just guessing, but less bypass volume might make it lose prime more easily.
    The APU, doesn't return much, if any and the filter isn't going to take much to plug. Probably, the APU will run out before tank is empty.
    I've run TK reefers out a few times, and started them after priming with the plunger or the bulb(like a remote tank on a boat).
    Been around smaller diesels since I was a kid, stuff happens, and you learn from it.
    One more thing, ISX has an electric charge pump, and should prime itself with key on for a long count, off and on again, maybe 2 more times. Still not a fan of the Cummins.
    Bean Jr. and Brettj3876 Thank this.
