How much torque can a 3.55 ring and pinion take?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerfromatx, Oct 24, 2013.
  1. truckerfromatx
    truckerfromatx Bobtail Member
    38
    16
    Mar 27, 2011
    Austin, Texas
    I stopped at a shop in Houston to have the power in my T-600 with a Cummins turned up. He bumped it to 450 hp and 1650 pounds of torque. He said it was the maximum. Do I need to change the gear ratio to a lower or higher number?
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Its probably the rating of the transmission that they are talking about. No dealer will turn it past that rating.
    You have to go to the aftermarket to get it turned up past the trans rating. I would not let the driveline rating stop me from turning a truck up.
    Cetane+ Thanks this.
  4. 062
    062 Road Train Member
    6,276
    33,781
    Oct 20, 2013
    Never seen ring gear problem, trans yes.my mechanic built twin turbo e model. Put 1402 to roller before input shaft broke.
  5. truckerfromatx
    38
    16
    Mar 27, 2011
    Austin, Texas
    Thanks for the info. I guess my mechanic is a firm believer in corporate propaganda.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    or possibly thats as high as that cm will go without major internal modifications
  7. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    The input shift is usually the one to break.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Liability, if he turns it up over the rating and the trans breaks, who's responsible for the damage? Say for example, you just put that trans in the truck, and it has a warranty, you have it turned up over the rating and it breaks, now the trans warranty people find out it's turned up and void the warranty, who get's blamed, you for telling the mechanic to turn it up or the mechanic who turned it up?
  9. truckerfromatx
    38
    16
    Mar 27, 2011
    Austin, Texas
    I should have mentioned that I have a transmission rated at 2050 lbs. of torque. I've gone with the Bully Dog ecu to bump the power.
  10. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    The guy who owns the truck. It's really that simple.
  11. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    You're fine, just don't drive like a lunatic and your entire driveline will handle a lot of power.
