How much weight can this Freightliner Columbia 3 axle handle.
Discussion in 'Heavy Haul Trucking Forum' started by Trukie, Aug 20, 2021.
  1. Trukie
    Trukie Bobtail Member
    26
    10
    Dec 4, 2020
    I have a freightliner columbia stock 3 axle 12k/40k axles
    3 axle 40 ton fontaine(+1)
    12.7 detroit
    470hp
    1700tq
    18sp
    390 gears
    What do you guys think it can handle?
    Ive done 90k feels fine but dont want to push it
  3. AModelCat
    161,678
    90k is nothing really. Not gonna hurt it.
  4. Trukie
    26
    10
    Dec 4, 2020
    How much can i do with regular 12k/40K axles then
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If you drive it easy without dumping the clutch on hills where you must stop on them it can haul closer to 100,000 every day with permits and keep on doing it for a long time?
    ABfish and beastr123 Thank this.
  6. 201
    201 Road Train Member
    12,639
    25,969
    Apr 16, 2014
    high plains colorado
    Load the wagon,,,just make sure you can stop the dang thing.:eek:
  7. beastr123
    beastr123 Road Train Member
    2,924
    23,981
    Jan 2, 2014
    Moose Jaw SK CAN
    My 96 IHC was spec'd the same and that was for hauling up to 9 axle (158kgross). I thought nothing of running 120k gross on 6 axles.
    If you have 40-145 drives then your gears are good for 145 gross and us in Canada use that set to pull super-B trailers up to 140k.
    With your light Columbia and a 40 ton with a pin-on 3rd axle you should be able to permit up to 114k almost anywhere in the lower 48.
    14k on your steers
    40k on your drives
    60K on the trailer
    That should let you put about 75k on the deck if you can axle scale it.
  8. Cattleman84
    Cattleman84 Road Train Member
    9,999
    71,348
    Nov 1, 2017
    The Sticks, Idaho
    That truck can handle more than you will ever want to put behind it.
    stwik and beastr123 Thank this.
  9. okiedokie
    okiedokie Road Train Member
    13,413
    104,711
    Jun 13, 2011
    PNWET
    6 axle with a Iron wolf brush hog 106k net. Piece of cake. :D
    baha, circle h, lynchy and 3 others Thank this.
