How NOT to RGN across tracks.
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Aug 21, 2022.
  1. Truckers Report Jobs
  2. bamanation
    bamanation Heavy Load Member
    797
    915
    Jan 22, 2009
    Muscle Shoals ,AL
    Just an FYI. At every RR crossing that you come to. There is a blue tag “sign” on the pole on either side of the track. It will be an 800 number and track location number. Do not call 911 do not try to move off of the track. Go immediately to the crossing pole and call the number. They could easily stop all track movements and could save your equipment and insurance a lot of money. 911 will not call that number for you. It is your responsibility to call it in. Hope this helps if you’re ever stuck on a RR Track.
  3. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    I use to haul super oversized loads. We called everyone we crossed, before we crossed.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Didn't watch it all but instead of just burning rubber he should of inflated his bags some more. That just might of got it up enough to go
  5. MacLean
    MacLean Road Train Member
    1,357
    4,003
    Sep 12, 2017
  6. Big Road Skateboard
    6,653
    37,338
    May 2, 2021
    Same thing i was thinking. Used to maje tons of service calls to the local factories because landing gear wouldn't come up.
    Yard dogs would jack em around annd often have em in a bind. Pull the leveling valve rod, raise till the shoes are off the ground. Crank up the legs a bit, and reattach.
    Same thing
    Brettj3876 and stuckinthemud Thank this.
  7. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Makes me wonder. Valves on the trailers adjustable ride height adjusters on the trucks my guys would have been off there in a flash. Looking at that crossing I might have had it all aired up before I attacked it. A lot of the crossings we deal with are rural, or worse, on industrial roads. Either way they tend to just ramp the road up one side of the berm and down the other. Adjustable link rods on the trucks have cured a lot of headaches.
    Bean Jr. and Brettj3876 Thank this.
  8. brian991219
    brian991219 Road Train Member
    2,999
    6,091
    Aug 10, 2013
    Lords Valley, PA
    I am suprised that more lowboy type trailers are not equipped with an over-inflate system to raise the suspension a few inches at the push of a button. We have had them in the car haul world for a long time, raises both tractor and trailer by up to 6 inches.
    Really simple system to install, so important that they are pretty much standard equipment in today's car haulers. Flip the switch before crossing any questionable grade level obstrutions and avoid the problem all together.
    Bean Jr. and Hammer166 Thank this.
  9. kranky1
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Some newer trailers are built with multi position ride height adjusters. All my older trailers and the trucks have been modified to adjust height. Pretty handy if you need to duck under something or clear a high curb.
    brian991219 Thanks this.
  10. D.Tibbitt
    152,845
    I sae that video when it was posted since i follow that channel. Thank god for the camera man had the brains to call the railroad phone number.. Luckily the loco engineer shut er down in time....
    Bean Jr. Thanks this.
