Like the title says: how often did u use ur JB ? I'd heard an mechanic guy in CA saying just dont use the Jake Break too much cuz its create a back pressure for the pistons and its not a good idea ! Its true ? Can any one school me on this ?
How often did u use ur Jake Brake ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Reddevil, Feb 21, 2012.
Page 1 of 7
I only use mine when I'm in 5th gear going through the truck stop parking lot.
Fullforce, Restlesheart and nakoBilly Thank this. -
not too ofter. really
The only time I DON'T use mine is when the sound might disturb people (residential, in town ect) or, when roads are icy. Otherwise, it's on ALL the time. The engine brake is for slowing the truck down and service brakes are for emergencies.
JohnP3, Rock hauler, nakoBilly and 3 others Thank this. -
^^^^What he said x2
same here x3
our trucks are mainly equipped with engine brakes and hydraulic secondary retarders
retarders are very very powerful, lot stronger than engine brakes but they works well only on larger speeds ( above 40kmh/25mph)
so we use engine brakes at lower speeds or combination of one and other but on lower power always
but always keep in mind to be careful on slippery wet and icy road -
Its not going to cause undo pressure on the pistons. The compression and powerstroke have more pressure on the piston than closing the exhaust valve somewhat. They have it engineered right...you have nothing to worry about...not if they are adjusted wrong...ie to tight or to loose...I could see that causing problems. They put more stress on the rocker arm than the piston.
I never use jake brake. ever. and being that I have none has nothing to do with it!
Page 1 of 7
