How often do you lube your wiper mechanism?
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Sep 18, 2019.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I have never seen this addressed before and I figure it must happen sometime but have never seen or heard of it being done. Should I be doing it or is the mechanism good for the life of the truck with no maintenance?
    daf105paccar Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,895
    May 25, 2017
    under a shade tree
    in all my years since i got my first drivers license at 16 (nearly 60 years ago?? quick guess) and all the cars, pick up trucks and motorcycles i ever owned, and all the big rigs i ever drove, have i ever heard of this being done.
    PE_T, starmac, D.Tibbitt and 3 others Thank this.
  4. Cat sdp
    Cat sdp . .
    21,124
    74,505
    Apr 8, 2012
    Orion's Belt
    I’ve never touched them , except the one time I had to replace the wiper transmission (I believe that’s what they called it) it was all the linkage and it wasn’t cheap.
    Might not be a bad idea tho.....
    PE_T, D.Tibbitt, Intothesunset and 5 others Thank this.
  5. Rideandrepair
    17,387
    56,459
    Aug 8, 2015
    I’ve never greased the linkage, I have replaced it though. Might be worthwhile. Whole assembly for my Classic is expensive. Trucks 20 yrs old. Already replaced. Drivers side assembly, rest is sloppy. I’ve had them jam up and burn motor out. Maybe a shot of silicone spray or dry lube for trailer sliders, or garage door dry lube, a graphite spray would work better than grease.
  6. buddyd157
    13,582
    34,895
    May 25, 2017
    under a shade tree
    sometimes the motor burns out for one of 2 reasons
    1) a truck wipers are used for longer periods of time, over the average 4 wheelers, so that uses the motors life considerably.
    2) if not enough moisture on the windshield, the wipers do not glide as easily causing the motor to work harder.
    if you got 20 years out of that transmission, that ain't too shabby a lifespan.
    nearly any lube will wash off, then too, you run the risk of splash up to the glass, and smearing. and if that does not happen, the lube can fall into the cowl area, and run into any drainage holes, and clog those up, backing up water into the cowl and maybe into the vents, and into your cab.
    on average, the only thing that wears on the transmission is where the "ball" of the lever on the motor's arm connects to the transmission pivot, as it is softer metal that that ball. but i certainly never had any problems over my entire life of using wipers.
  7. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    I have never messed with them other than replacing them but that's actually not a bad idea. Maybe keep the ends from wearing and getting slop in them ?
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    lube what part of mechanism? the moving parts are metal-plastic pairs. what to put in there? silicon grease? I would not touch it.
  9. pushbroom
    pushbroom Road Train Member
    1,780
    7,318
    Sep 1, 2012
    Fix it when it breaks. Otherwise continue on
  10. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    I have lubed a few of them over the years.
    I used white lithium spray grease in an aerosol can.
    I would give all the ball flex joints a little spray while I was in there repairing something else and they were accessible.
    Never did it as general maintenance.
