How often to change oil/filters in '2000 Freightliner FLD with Cat C12
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, May 4, 2019.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    I have the above mentioned truck with 460,000 miles. My question is how often to change oil.
    I want it to live a long life. Thanks
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Put an oil bypass on it like OPS to keep your oil clean and do regular oil samples and change it when it needs it not by some made up milage. Or if you want to just do it every 15-20k and you should be good.
    ichudov Thanks this.
  4. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Which bypass would you recommend?
  5. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    In front of filter is a cap, uses a half in ratchet to remove, the buy a cat bypass, 1w-8845 is filter is memory serves correct
  6. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    What kind of bypass is it? jUST A HOUSING FOR THAT ADVANCED efficiency filter?
  7. ClineER
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    The oil filter housing has on the engine has provision for bypass that's just capped off, remove cap and install this filter. It is a cat bypass filter designed for engine
  8. Kw Owners Club
    Kw Owners Club Bobtail Member
    42
    22
    Jan 1, 2019
    Every 20000kms or 12500 miles
  9. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Thanks. I have some doubts about whether it is too late to install a bypass. We change oil ourselves so it is not that expensive. Anyway, I will stop by our Cat dealer and ask them for suggestions on bypass. If I can get another 300-400k out of this truck. that would be plainly awesome. It is old and not without problems, but these are simple and cheap problems so far. (knock on wood)
  10. redgod7
    redgod7 Light Load Member
    67
    41
    May 18, 2013
    Detroit, MI
    I personally go by hours. Last oil change I was at almost 800hrs. I don't have a bypass filter but I use oil analysis. I've got a C15 btw.
  11. Mrdewdew
    Mrdewdew Bobtail Member
    4
    May 6, 2019
    Ditto what everyone else is saying . Take a oil sample. But regardless of the oil sample replace the oil filter every 10,000 miles. Or take oil samples of whatever oil your using every 250 engine hours and send it to the lab. Run it til they say it's bad.
