How often to change oil over 500K?
Discussion in 'Volvo Forum' started by Dave_in_AZ, Nov 14, 2015.
  1. Dave_in_AZ
    383,942
    I'm looking at a Volvo with a VED13 / 2011/670. Its right at 500K and I'm wondering how often you guys would recommend changing oil & filters or standard PM. Thanks.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    1.6 m on my N14 and I change it every 20,000 miles.
    Dave_in_AZ Thanks this.
  4. Dave_in_AZ
    383,942
    What brand do you swear by?
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    i woulds say every 15000 but go with delvac 1300 super or shell rotella triple t protection do not go with fleet oil which is what a lot of places offer
  6. spyder7723
    spyder7723 Road Train Member
    15,470
    25,061
    Mar 31, 2013
    sarasota, fl
    Do oil samples and change it when the samples say you should. Unless you idle a lot probably around 25k miles.
  7. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I just use Rotella nothing special
  8. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    Volvo has a service at a glance sheet which bases oil change intervals based on fuel mileage. With oil formulas now the old 10k mile oil change is no longer the norm. Using fossil based oils the interval is 15-30k miles. Using synthetic oil does not change the interval I don't care what anyone says. Also Volvo will void warranty on extended services should an engine failure occur. I am not a fan of synthetic oil in an engine for a number of reasons. Synthetic oil in transmissions and differentials is different because they are sealed. Engines have soot that breaks down the oil and actually turns it into an abrasive. That is my dealership advice.
    My fleet owner advice is if you know or can find out the last oil change mileage monitor the oil pressure. See what it is at idle, 1000 rpm and at 1400. Hopefully you have 10-15k miles on it. If not wait till you do. Change around the 15k mark and check what new oil pressure is at same rpm as before. That will give you an indicator of engine internals. Get a sample. Use that as a base line then sample every quarter. Using additives like Lucas will give a false reading. Brand is a personal preference. Mine is Delvac. We sell Delo at the dealership. I do not like Rotella at all. As for synthetic if you have any oil seepage like upper gear cover it will make it a full blown leak. As for the intervals I would say 15-18,000 no more than 20k. If you have 5.5 mpg then I would consider 13-15k if you have good oil pressure. The D13 is a solid engine and has very few issues with the rotating assembly. Just stay on top of your maintenance.
  9. Dave_in_AZ
    383,942
    ^If I get less than 6.5 MPG I'm gonna be HUGELY disappointed. I've never been a fan of synthetics either.
  10. spyder7723
    15,470
    25,061
    Mar 31, 2013
    sarasota, fl
    Don't know how volvo does it, but I've owned Detroit's that came from the factory with a bypass filter for extended drains. As long as you follow a strict oil analysis program the warranty was not effected.
  11. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    With our 2008-2016s Volvo,motors and cummins we do every 15k even tho they swear that you don't have to change it for 25k on the newer ones. We don't play that we stay pulling hills
