If I failed the DOT physical test for too high of a blood pressure or something, how soon afterward can I retake it again?
How soon can I retake DOT pgysical if I failed?
Discussion in 'Questions From New Drivers' started by supremeguy, Mar 29, 2011.
My advice?..Go find out why your blood pressure was up?
Serious issue that can cause alot of organ damage. -
There is no time frame, go to the doctor get some high blood pressure medicene, when it comes down, go retake the physical
well mine is like 135/82, is that alright?
and what about BMI? I think I'm overweight, 5'6 and weighs 170lbs
135/82 is not failing - above 140/90 is. And by most standards, you might have an extra 10-15 lbs on, doesn't make you overweight... if you're as new to the industry as I tink, I promise, you'll SEE what overweight is...trust me.
There are no current regulations for BMI, I dont remember the numbers for a failing bp, mine was 132/80 and that was fine.
Right, but 170 at 5'6" isn't bad... my max weight in the Air Force, at 5'7", was 179. And I was wearing 34" waist pants and wasn't fat at 180. His "overweight" won't get a second look.
