How strong is a typical 12.7 detroit engine brake?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by double yellow, Apr 14, 2015.
  1. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I'm kinda leary of butt dyno results, but it feels like there is less response at low rpm (1050-1200). Once boost builds it feels like the power is comparable.
    I haven't filled yet, but going by scangauge I got 8.9mpg in the last 1400 miles. 1/2 of that was at 45,000 lb, 1/2 at 63,000 lb. 30' to 3700' to 2300' to 4300' to 30' and back... That is in line with expected mpg, though perhaps a skoosh low. I'll have a better idea after a month
    icsheeple Thanks this.
  3. fortycalglock
    fortycalglock Road Train Member
    6,158
    6,592
    Jun 25, 2011
    Tourist Town, FL
    The first hose I check is the one from the compressor to the intake.
    double yellow Thanks this.
  4. 062
    062 Road Train Member
    6,276
    33,783
    Oct 20, 2013
    If you had overhead run when you put the jakes on, that could be your mpg drop. Mine will drop 2-3 tenths after a overhead.
  5. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    I've got some graphs/tables Somewhere (that I can't find at the Moment) that Give the BHP produced by "jakes" on various Engines..
    From memory the Series 60 produces (regardless of HP rating) 350Hp of Braking effort.
    & the ISX/signature (Regardless of Hp setting) produces 600Hp of braking effect.. BISTBC..
  6. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    the ones made by "Jake", work better than the other makes. You might have gotten better holding power out of an actual Jake brake.
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Perhaps.
    Unfortunately, I could not get a Jacobs for my 2000 mk 12.7. It was an oddball model & year, the folks at Jacobs were more interested in their newer applications to be of any help, and ultimately no one stocked the necessary parts except pacbrake.
    Anyway, it seems 2100rpm is the upper limit, not 1800 (an extra 17%), which, when combined with 29% more boost, ought to give me nearly 50% more braking power -- an amount more than satisfactory (especially having come from no engine brake at all).
  8. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    The compression brakes always work better at higher RPMs. Well tell us how it does on your next trip. Good luck keeping it cool (the brakes).
  9. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    I see what you did there. Lol. Stay frosty...
  10. Phantom307
    Phantom307 Light Load Member
    222
    210
    Jul 5, 2019
    Cheyenne
    I am 9 years late to this party. How dare they leave me on a cliff hanger like this! Did he survive!? What happens when you take the 60 series to 2100 rpms on a jake brake???
  11. Big Road Skateboard
    6,660
    37,397
    May 2, 2021
    Lots of things could happen. If your Jakes are working properly, and you take RPM's to 2100, and then turn your Jake switch on, and THEN let off the throttle?
    What will happen then?
    Your Jakes come on
    Sons Hero Thanks this.
