How tall/heavy do you have to be?
Discussion in 'Questions From New Drivers' started by apaulson, Mar 2, 2007.
  1. apaulson
    apaulson Bobtail Member
    Im studying for the CDL permit, anyways I told my older brother who came over about me wanting to go to a trucking school one day, and he laughed since he thinks im not big enough??
    I always thought size did not matter, I am 135pounds and 5 "10
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Well the 135 will probably go up after you become a driver!:smt003 As long as you can pass the DOT Exam I don't think you will have any problems.
  4. slim66
    slim66 Bobtail Member
    30
    Mar 3, 2007
    Some jobs may have physical requirements, such as how much you can lift, but if you are strong enough to haul yourself into the truck, press down the clutch, you can certainly drive a truck.
  5. pro1driver
    pro1driver Heavy Load Member
    939
    47
    Mar 30, 2006
    North East, USA
    i worked at a company where this female driver was 5' 4" and 100 pounds soaking wet. she could (and can) out drive, out manuver any sized rig and make a 6'6" male driver cry.............
    as long as you can pass a DOT physical, you can drive.
    by the way, i am 5' 9.5", and i weigh (ok, overweight), a hefty 195 pounds.
    tell your brother he's full of it...............:headbang:
  6. apaulson
    thankyou all for the info, now I know I still have a chance :)
  7. Gearjammin' Penguin
    2,635
    8,020
    Feb 18, 2007
    Central AZ
    When I started driving, I was 6'0" and around 120. :eek_1:
    I made you look like Joe Pesci. :biggrin100 (22):
  8. drive55cat
    drive55cat Medium Load Member
    313
    14
    Mar 3, 2007
    Pa
    If you stay away from flatbed companies and tarp loads you will be allright, I drive a Century class Freightliner automatic which I did not think I would like but it is a good truck. The steel tarps weigh about a hundred pounds each and the lumber tarps are about one hundred thirty pounds and a lot of loads require two tarps per load. I see more ladies at the wheel every day, I met a peer flatbedder who was sixty two and about one hundred fifty pounds and she finished folding her tarps and offered to help me fold mine, she was behind me in line. Plenty of work if you can handle the lifestyle. goodluck drive55cat
