How to avoid the Cross Bronx
Discussion in 'Experienced Truckers' Advice' started by lifesafight, Dec 4, 2012.
  1. lifesafight
    lifesafight Light Load Member
    109
    10
    Jul 15, 2007
    East Orange, NJ
    I travel on this road often and I here there is a way to avoid it heading from jersey to Long Island. Are there any ways to avoid this road?
    Thanks
  3. fortycalglock
    fortycalglock Road Train Member
    6,157
    6,587
    Jun 25, 2011
    Tourist Town, FL
    Goethels or Outerbridge crossing, but then you have to deal with the BQE. Crossbronx is the fastest way to LI except at night.
  4. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    1. Coming from the south, you can come in via 278 (Goethals Bridge), or 440 to 278 (Outerbridge), then over the Verrazano, and run 278 to 495. I don't like to go this way unless going to Brooklyn, as I have terrible luck getting stuck in traffic on Staten Island.
    2. Coming from the north via 87, you can go across Westchester and come down the eastern side via 287 and 95 South to the Throgs Neck/Whitestone. Roundabout, probably will lose time due to mileage increase.
    3. Also coming from the north via 87, you can continue into the Bronx on 87, and take the Major Deegan over the RFK/Triboro bridge to 678/Van Wyck, to 495. Not recommended, major airport traffic this way.
    4. Roundabout, but works SOMETIMES...coming in from 95, you can exit the Cross Bronx, head south on the Major Deegan, which turns into the Bruckner Expressway as it heads back north toward 95. You can then get on either the Whitestone or Throgs Neck from there.
    There's more than one way to do it, but the Cross Bronx to Throgs Neck is the most direct, and often the fastest route to LI.
  5. JackTheWhack
    JackTheWhack Light Load Member
    50
    28
    Oct 31, 2012
    Eagle River,Wisc
    All of those routes are good...But...This one works best...Go up to Bridgeport CT and take the Ferry over !
  6. T...Street
    T...Street Light Load Member
    182
    176
    Aug 19, 2012
    randolph co. NC
    Or this....stay way south of NYC to begin with.......
  7. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    From the West sometimes when the cbe is gridlocked I go around on 287 an cross the tappan zee bridge and come back down 95 to the whitestone or throgs neck. Its been a while so I dunno if theres construction or not. But I always had better luck that way if you end up in the main part of rush our. Granted rush hour is 5am to 9pm there...
  8. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Correct on all counts Pound Puppy.
    I have been running in/out regularily the last few months and have been useing the GW/CBE in the middle of the night and on weekends. Failing that I have been running 40 miles out of my way and crossing the Tapanzee and Throgs Neck.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,386
    7,836
    Jul 11, 2012
    in the bush somewhere
    Just close your eyes when crossing GWB and keep them shut till the bouncing stops. Havent been up there in a bit, is it still so rough under the apartments?
