How to back. The straight back set up. Use this at truck stops also.
Discussion in 'Experienced Truckers' Advice' started by Wooly Rhino, Aug 23, 2012.
  1. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    The key to backing is the set up. But no one seems to tell you how to do a set up.
    When you wish to back straight up, as at a truck stop, pull down to the row of trucks you are wishing to back into. With your trailer straight you should be about four feet in front of the other trucks. Drive one trailer length pass your hole or just past the truck beyond your spot. Turn your truck away from the line of trucks and head straight away from your hole. One third of the way up make an S turn first to the drivers side and then straighten out. Once your trailer is straight you should be lined up into your hole. Straight back in. Easy Peasy.
    Ole Timer, geppetto and Sam Hell Thank this.
  3. good for nuthin'
    good for nuthin' Light Load Member
    87
    51
    Dec 8, 2010
    Las Vegas NV
    I find this can still be confusing for some drivers as they don't fathom the parts in the back up. What is good to add, is that the tractor is pushing the trailer,using the tandems as the pivot point(and steering with tandems) in the second part of the turn.
  4. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    You mean I can't just pull up straight in front of the whole and just back straight up ? Well dang something else I have been doing all wrong !!!
  5. Keyster
    Keyster Light Load Member
    277
    143
    Jun 15, 2012
    Sorry but that was about as clear as mud.
    A21CAV Thanks this.
  6. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    Got it,
    Thank You !
    :biggrin_2559:
    allniter, A21CAV and Ole Timer Thank this.
  7. Doublecutter
    Doublecutter Light Load Member
    142
    39
    Dec 23, 2011
    10,555
    5,746
    Oct 22, 2010
    32179
    dfhjfjhgh.jpg here ya go.........
    olphart, Sam Hell, gb2nyc and 14 others Thank this.
  9. Worthken
    Worthken Light Load Member
    265
    83
    Jun 2, 2012
    Delmas South Africa
    Thanks for the laugh I'm still wiping of the tears.
    bullhaulerswife Thanks this.
  10. LonesomeTrucker
    LonesomeTrucker Bobtail Member
    27
    20
    Jun 1, 2012
    New Brunswick, Canada
    This^^^
    that diagram sums it all up!
  11. Worthken
    265
    83
    Jun 2, 2012
    Delmas South Africa
    I can only imagine the guy performing that maneuvre. Sweating, arms floppy, and left leg trembling from pushing the clutch. When he gets out of truck after a hour he still feels proud of himself.
