How to bobtail a dolly?
Discussion in 'Experienced Truckers' Advice' started by Brandonpdx, Aug 31, 2012.
  1. Brandonpdx
    Brandonpdx Road Train Member
    4,240
    4,049
    Dec 27, 2007
    Elkhart, IN
    What's the right way to pull a bare converter dolly behind a lead box? It came up today but I had to plead fng to the dispatcher and leave it at the shipper. Do you connect the red side but leave the blue disconnected?
  3. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    You would hook it up as you normally would in a set.
  4. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    You only hook up the electric pig tail. You do not want the brakes operable on an unloaded dolly.
  5. buszzbait
    buszzbait Bobtail Member
    11
    Great Falls, MT
    Just what he said. Only hook the electrical cord. Wrap the air lines so not dragging and connect them to each other and good to go.
  6. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    plus as always, make sure the safety chains are attached..!!!
    and DO NOT go like a mad man, as that dolly will be hopping all over the place...
  7. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    The proper way is to hook both hoses and the power cord, open the emergency valve "Red", but leave the service valve, "blue", closed, as well as hooking your safety chains. The reason for this is that the air system on the converter dolly is then "charged" and the brakes released, if you were to turn the service valve on, every time you touch the brakes, the convertor wheels will lock up and drag the tires, "no weight on wheels", the reason that you would always leave the emergency valve open is so that the system is charged, if the convertor were to come loose, then the brakes would lock up and bring it to a stop, granted this would only happen during a wreck of some sort, or a structural failure in the rear of the lead trailer, and most likely not then, but you see the theory, also, you don't want to be pulled over with a hose or two just dangling and not hooked up, then would come the DOT Inspection and everything that goes with it.
  8. papawheelie
    papawheelie Light Load Member
    62
    31
    Jul 30, 2012
    Phoenix, AZ
    This makes a lot of sense. Learning...
  9. Taildragon
    723
    449
    Jun 22, 2012
    Indiana
    You will keep learning until you retire, which is a good thing, the bad thing is, you keep forgeting, and having to relearn as you get older...
    danmissouri, Shaggy and Zen Trucker Thank this.
  10. okiedokie
    okiedokie Road Train Member
    12,180
    90,466
    Jun 13, 2011
    PNWET
    Right plus pintle air ram
    papawheelie Thanks this.
  11. Taildragon
    723
    449
    Jun 22, 2012
    Indiana
    Good point okiedokie when the system is charged the ram on the pintle hook will engage and keep the slop out of the hitch. Believe it or not, you will feel the slop in the cab if you do it without the system charged.
