How to break in a new truck
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Jan 23, 2018.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    My wife and I will soon buy a new Volvo 780 with the D13 iShift combo. What, if anything, should we do to make sure we break it in properly?
  3. Ridgeline
    22,386
    116,292
    Take it easy, no drag racing with old men in a silver Prius.
    Just keep your foot out of it for a few thousand miles and when you do an oil change, get a OA done for a baseline.
    Speaking of oil ...
    Think about running synthetic.
    Dan.S, ladr and Midnightrider909 Thank this.
  4. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Which company for OA?
  5. ladr
    ladr Road Train Member
    1,383
    15,431
    Apr 14, 2013
    GA
    Read the owners manual.
    Good luck.
    Dan.S, Midnightrider909, nax and 2 others Thank this.
  6. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,190
    Aug 26, 2014
    LLMF
    What @ladr said.
    New trucks today don't require a break in like the old ones did. There may be a few initial extra maintenance items.
    Midnightrider909 Thanks this.
  7. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    If you want a truck to run strong, run it strong so it knows what to do and blows out all the weak junk then replace with HD , if you want a weak truck, pay no attention, do no service. but still replace bad parts.
  8. Ridgeline
    22,386
    116,292
    I've been using blackstone for a long .... long time.
    The one fleet I bought was using apex and greenway. I think greenway is gone now but I get something from apex every few months.
    By the way. It isn't about breaking in the engine but the drive train, beat it to death when new it won't last.
  9. reddove
    reddove Medium Load Member
    333
    147
    Jan 6, 2013
    San antonio, Texas
    I got my Volvo 780 brand new (2017) and what I did was do oil samples through a lab every oil change and here is what I found out. I used semi-synthetic 10-30 oil. The first year and a half change your oil around every 15,000 miles. It’s going to be throwing out a lot of metals and junk because it’s breaking in which is normal. You can drive your truck as normal. When you hit around the 160,000 the metals levels will start to level out and drop and you can start extending your oil changes to 20,000-25,000 miles depending on how you drive. The lab where I sent my oil samples is now telling that I should try and extend my next oil change to 27,000 miles and check again. My truck is now at 180,000ish miles. With the Volvo 780 don’t be surprised if you have to change all 4 of your batteries in a year. When the first one went out I let the dealership do it and they charged 300. When the others went I changed them myself and got the batteries from autozone. The batteries cost $100ish with the core return and $130ish with out it. The batteries from autozone have a CCA of 950-1000 and reserve of 195. Which is better than the OEM Volvo batteries of 170. And the batteries from autozone have a one year warranty. Also the Volvo has a lot of filters. 3 oil filters, a coolant filter, two fuel filters. Two cab filters. DEF filter (which you change at 150,000 miles which you should have done it cost about $750 and the dealership does it). I had to change an emissions sensor twice ( no charge warrenty repair) and then I had the steering pump replaced because it was making growling, bear like noises. After that the truck gave me no issues.
  10. benthere
    benthere Medium Load Member
    321
    227
    Feb 14, 2008
    The shomee
    drive it like you stold it
    TruckRunner and Steel Dragon Thank this.
  11. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Drive it like you stole it.
    pmdriver Thanks this.
