How to clear ECM codes, 2008 International Prostar
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greggg, Aug 8, 2018.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    Hello,
    One of my codes, coolant level temperature is not allowing me to perform a regen. Mechanic shop was supposed to work with my warranty but messed up by claiming a part that isn’t covered caused the mechanical failure. I’m changing the water pump myself, but was wondering how would be able to then clear codes for me to perform a regen ?
    2008 international prostar ? Just unhook the batteries ?
  3. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    If you repair the condition in which the fault is coming active it should not need to be cleared. Low coolant or coolant temp faults once corrected should go inactive after a key cycle and short 1 min runtime if we are talking Cummins. Once the fault is inactive it will not affect the trucks ability to regen. If you still have an active CEL it will need to be troubleshot.
    Greggg Thanks this.
  4. Greggg
    161
    35
    Jun 30, 2018
    Thank you my mechanic friend is saying the same thing. Thanks Goodysnap.
    Goodysnap Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    My Detroit will clear fixed faults after third successful start.
    Greggg Thanks this.
