How to connect shop air to air up truck?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Thetrashnoob, Apr 1, 2021.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    281
    50
    May 30, 2019
    Trying to help a friend who just bought a tri axle dump truck, and after sitting for a few hours it’s losing a lot of its pressure. The primary air valve has a tire fill port, is there a better place to hook up air to air up the truck? The air dryer?
  3. lester
    2,918
    7,874
    Jan 2, 2012
    NW, Iowa
    I have Valves and quick connects on my air tanks to get air or fill tanks with air. I did have some trouble with my air governor on the truck after doing that a bunch but my shop air was at 160ish psi. Proper way would be taking hose of air compressor and putting shop air in there I suppose
    stillwurkin Thanks this.
  4. p608
    p608 Road Train Member
    2,181
    2,992
    Nov 10, 2016
    Why not just fix the air leak?
    Roger McG Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,708
    8,992
    Jul 12, 2017
    When checking the complete system, I connect direct to the discharge line right at the compressor. #10 male flare with a shutoff valve and your shop hose nipple is all it takes for most older stuff.
  6. lester
    2,918
    7,874
    Jan 2, 2012
    NW, Iowa
    That's what he's trying to do
    stillwurkin and Dave1837 Thank this.
  7. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    I had to do this last spring when my truck was pinned against the wall in the polebarn and I knicked a battery cable hooking up the batteries blowing the ECM fuse under the hood. .
    I pulled a drain plug off one of the air tanks and went down to Ace hardware and bought a male fitting of the same size that had a female thread to insert a male npt fitting in.
  8. DUNE-T
    DUNE-T Road Train Member
    6,919
    16,751
    May 10, 2015
    Detroit, MI
    Connect to air governor on the compressor
    tommymonza Thanks this.
  9. Mattflat362
    Mattflat362 Road Train Member
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I have a female right behind my cab but I have never used it and I have never looked to see where it goes. I can take pics and get details tomorrow but by then you will probably be all squared away...
  10. tommymonza
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Pics of Female?
  11. p608
    2,181
    2,992
    Nov 10, 2016
    Sorry, I misunderstood, I thought he was trying to bypass the problem.
