How to disable a brake chamber
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Skate-Board, Sep 22, 2015.
  1. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    I just had new drums, brakes, springs and bushings put on my trailer. One of my brakes is not releasing and dragging. If I step on the brake it sticks. It looks like the rod that is attached to the S cam and slack adjuster needs new bushings.
    I need to disable that brake chamber and don't know how. I tried backing off the slack adjuster but since the brakes and drums are new there is no room to back it off.
    I spent an hour outside trying to take the clevis off the rod. I got the cotter pin out but I can't budge the pin?
    Since I'm empty that dragging brake is real bad! Any ideas?
  3. 062
    062 Road Train Member
    6,146
    33,187
    Oct 20, 2013
    Almost sounds like they cut the rod to short. You should be able to back them off.
    Should be a cage bolt on side of can,insert in the hole in the can and tighten down
  4. OLDSKOOLERnWV
    17,840
    269,012
    T- bolt in the side of the chamber? Or if you have one in your toolbox it will help.
  5. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    T-Bolt? Cage bolt? Not sure what that is? Is that the rod they stick down the chamber? Is there a nut on it? Never done this before. I'm at the Loves in Bennett, CO and they don't have a clue.
  6. Ruthless
    Ruthless Road Train Member
    8,810
    86,336
    Aug 28, 2010
    The City.
    It has little ears on it. When you get a new brake chamber you can get it off easy. Stick the end with the ears into the inspection port on the can. Push in and half twist to engage. (You'll feel it: it's like a keyway) then take the nut that's on the caging bolt, and tighten it down opening the chamber up.
    MJ1657 Thanks this.
  7. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Ok. So tightening that rod will release the brake and keep it off? Keep in mind there is like 1/4" of play on the slack adjuster.
  8. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
  9. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
  10. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Thanks! Looks simple enough. Although. I got the bright idea to take the covers off my air horns and paint them. One screw broke off in the hole. That ended up being a whole day affair trying to drill out the screw. I was going to use an EZ Out so I drilled a small hole into the screw. The drill broke off. This is how many of my simple tasks turn into a major ordeal.
    icsheeple Thanks this.
  11. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Penetrating oil is your friend, my friend....
