How to find parts for a old engine
Discussion in 'Ask An Owner Operator' started by Coffey, Jun 14, 2020.
  1. Bob Camden
    Bob Camden Bobtail Member
    21
    9
    Jan 9, 2018
    My guess is that pretty well after the BSX ACCERT nobody wanted a CAT anymore and threw them away.
    My 3406e has all parts available with many being on the shelf.
    That powers a 96 KW and I have no problem getting parts for it either.
    Opendeckin, Coffey and Shawn2130 Thank this.
  3. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    The older engines in trucks are found in almost anything that requires an engine, whether that be farm equipment, construction or mining that are still in use.
    So parts will be available for a quite a while yet.
    Newer stuff are more integrated in the machine they come in making it harder to switch to another machine.
    Dale thompson, Dino soar and Coffey Thank this.
  4. Truckers Report Jobs
  5. jamespmack
    215,914
    I knew were 2 v12 hall-scotts was located. In pieces. I'm not family and had no say in it. They were scraped with everything else in the old boys shop.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    I F'n HATE volvo. Need a head, No problem getting that dinosaur from cat lol. Cat should of bought mack LOL
    AModelCat, 650cat425 and Coffey Thank this.
  7. AModelCat
    160,514
    I priced out a head for my 3406 build. Parts guy could only find a handful and they were overseas. I'm going to rebuild mine. Even with my discount on parts it would save me about $2k to have my old head rebuilt.
  8. AModelCat
    160,514
    CAT still builds C15's and C13's. They're much more advanced than the truck engines though.
    650cat425, Shawn2130 and Coffey Thank this.
  9. bad-luck
    bad-luck Road Train Member
    3,316
    6,096
    Nov 16, 2013
    Baltimore, Maryland
    Engine parts can be found at the dealer. Sometimes, parts are discontinued, but usuallythey are for the truck it self. Then you need to look a a truck junk yard.
    Coffey Thanks this.
  10. Shawn2130
    894
    1,892
    Sep 20, 2015
    Ontario
    That’s impressive. What makes them more advanced than the truck engines?
    Coffey Thanks this.
  11. AModelCat
    160,514
    Well they have all the emissions junk on them now lol. I think they're all running MEUI C injectors too.
    CAT had supposedly come out with their next gen turbos too. I don't know if they are used on the 15/13 or just on their smaller engines. Rather than running twins, they use a single turbo but with 2 different sized turbine wheels in one housing IIRC. Front 3 cylinders feed one, rear 3 feed the other. Small wheel gives quick spool up, larger one makes the big boost when pulling hard. Pretty neat concept.
  12. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    I’ve got a Mack e9 v-8 that parts are a little scarce on. You can’t still get parts, but they are pricy. Volvo pretty much doesn’t support them anymore.
  13. Shawn2130
    894
    1,892
    Sep 20, 2015
    Ontario
    Would you happen to know what the turbo with the 2 turbine wheels are called?
    I tried finding info on it.
    Sounds like a neat setup, but how does “much more advanced and junk” go together? :D
    AModelCat and Coffey Thank this.
