... this is the fix our Pro mechanic did for the REGEN issue:
initially you will get 2 TWO errors and these can be reset remotely NP --- the issue comes
when you get FOUR ERRORS on the dash - and it's asking for the REGEN on errors 3 and 4
then it has to be repaired quickly - or you're on the side of the road -- using the replacement
as seen in the picture below.
I did upload images here you will get the idea -
** After installing do a computer regen and your good to go !
the part is $250.00
How to fix the REGEN Error issue > Updated - no chip repair - 2020 truck
Discussion in 'International Forum' started by JerryD13, Dec 12, 2021.
