How to Fix - Went in for Alignment and they said - Shackle of Spring EYE
Discussion in 'Volvo Forum' started by JerryD13, Mar 26, 2019.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    Hi Guys,
    I went into get an alignment - and the Tech said -on the Leaf Spring - the
    ** back part he called the Shackle of the Spring Eye was BAD
    he said both sides were bad on the BACK of the leaf Spring and needed to be
    replaced.
    How is the best way to get this fixed --- they quoted about $1.200 to get replaced
    bushing for shackle hanger - both are bad
    QUESTION IS - WHAT WOULD BE A EXPECTED REPAIR COST FOR THIS PROJECT
    Thanks in Advance
  3. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Your post is too generic and does not contain enough information to come to any relative conclusion.
    Is this a Volvo sedan or coupe? Smart ### aside........I think you get the point here.
    Are we talking steering axle or drive?
    What were you quoted $1200 to repair? Just spring pins and bushings replaced?..Or.......All 6 or just 2?........or........ New springs, shackles, ubolts hangers and alignment included?
    This can go many different ways as you can see.
    More info will get you some intelligent responses.
    JerryD13 and magoo68 Thank this.
  4. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    If it's just spring eye bushings sounds a little high, if it's complete spring replacement, sounds a little low. If you're not in a certified spring shop, that's where you need to be. Where are you located and who is doing the work?
    JerryD13 Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    Should be about half that amount, but labour ain't cheap nowadays.
  6. JerryD13
    169
    126
    Oct 17, 2016
    TRUCK 2012 VOLVO VNL -----> Correct - THE WORK IS FOR "2" BACK BUSHINGS - SHACKLES HANGERS ONLY - ** ALIGNMENT WAS NOT INCLUDED ** (GREAT POINT) - GOING TO CALL BACK IN THE MORNING AND GET MORE INFO --
  7. JerryD13
    169
    126
    Oct 17, 2016
    DENVER, COLORADO - IT IS A CERTIFIED SPRING SHOP - THIS IS ONLY TO REPAIR
    THE BUSHINGS - BOTH SIDES - DID NOT INCLUDE THE ALIGNMENT - THATS WHY I WENT THERE IN THE FIRST PLACE - BUT .. I HAD AN ISSUE I THOUGHT WAS ALIGNMENT ..
    Tombstone69 Thanks this.
  8. Goodysnap
    3,744
    9,105
    Jul 12, 2017
    Jerry,
    What symptom are you trying to correct with an alignment? While the spring pins/bushings may be worn and in need of replacement, it is unlikely that replacing them will change the steering angles enough to correct a wear or drivability complaint. Did you mention your complaint to the shop?......or just that you wanted it aligned?
    These questions are important to ask before approving the work, rather that getting it back to find out it's not going to correct your complaint.
    Tombstone69 and JerryD13 Thank this.
  9. JerryD13
    169
    126
    Oct 17, 2016
    Yes Sir - I had one Steer tire - that was wearing and I would feel a slight pull once in a while
    the shop is definitely Pro Level - the tech that was going to do the alignment showed me
    the leaf spring bushing - it was moving around. ---> (going to renegotiate tomorrow to include an alignment)
    Tombstone69 and Goodysnap Thank this.
  10. JerryD13
    169
    126
    Oct 17, 2016
    How to change leaf spring pins and bushings on a Big Truck
    npok and Diesel Dave Thank this.
  11. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Depends on the miles highly advise to replace spring as front bushings go as well. All in with new springs and bushings would be around 1700. I think it would be worth to spend extra money to get all new #### and not worry about it again but just my .02
