How to get a JOB driving a CMV.
Discussion in 'Experienced Truckers' Advice' started by 201773, Jun 9, 2023.
  1. 201773
    201773 Medium Load Member
    508
    865
    Dec 14, 2020
    If one wants to drive a CMV they must obtain a CDL from their local DMV.
    One must be aware of the FMCSRs from the FMCSA under the authority of the DOT. Preforming a PTI, filling out a DVIR, and understanding how to use an ELD is required.
    CMV companies will hire you with a clean report from the FMSCADAC. They will check your DR and your DAC.
    Be aware that compaines concerned with their CSA and their ISSS they get from the DOT because of the CVSA will look closely at your PCP.
    Have I left anything out?
  3. 201773
    508
    865
    Dec 14, 2020
    *Edit*
    They will look closely at your PSP not your PCP although they will check for PCP at the FMCSADAC.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    You left out the fact that just about everything you said is wrong. Which is the problem with absolutes.
    For example we don't even have a DMV in Michigan, it's Secretary of State's office.
    Compared to a total number of companies, only a small portion actually use DAC, it's not the boogieman some make it out to be. It's a private comapny selling a private service. Also, it's called Hirerite, hasn't been called DAC for over a decade.
    ISSS is a made up term, at least I've never heard it before and not finding any thing in relation to trucking in a google search.
    Companies can check a drivers PSP report, but it's by no means required.
    tscottme and Diesel Dave Thank this.
  5. Thrasher28
    Thrasher28 Road Train Member
    1,240
    3,507
    Aug 12, 2021
    Bowling Green, KY
    One also needs a medical card to get their CDL. I guess that falls under what you already said though.
  6. Broke_and_Hungry
    Broke_and_Hungry Light Load Member
    226
    517
    Feb 26, 2008
    He may mean CDLIS (Commercial Drivers License Information System), although this is normally not a necessary check until the CDL is issued.
  7. 201773
    508
    865
    Dec 14, 2020
    508
    865
    Dec 14, 2020
    Yes. They will need to see a Dr.
  9. ZVar
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    snowwy Thanks this.
  10. 201773
    508
    865
    Dec 14, 2020
    I did.
    ISSS stands for: Inspection Selection System Score.
  11. Cattleman84
    Cattleman84 Road Train Member
    9,995
    71,312
    Nov 1, 2017
    The Sticks, Idaho
    Which has ZERO information that anyone would check when hiring a driver.
    tscottme Thanks this.
