How to get the best MPG
Discussion in 'Questions From New Drivers' started by S0uppppp, Mar 17, 2017.
  1. S0uppppp
    S0uppppp Bobtail Member
    6
    Just looking for some further help on how to Maximize my MPG. I drive a 2015 Peterbilt 579 9 speed. I'm averaging 6.55 MPG but other drivers are almost to 7 MPG. Best RPM to shift at anything, to help increase it.
  3. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    Don't use full throttle to accelerate only use what you need I use about 30%empty and 50 to 70 loaded I don't hammer down up every hill either
    Dave_in_AZ and fargonaz Thank this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,811
    18,695
    Nov 1, 2010
    Burnsville, MN
    A bigger turbo and bigger exhaust tubes.
    Isn't bigger always better?
    Many years ago there was a test done to determine how acceleration affected fuel economy.
    It was found that full, or nearly full, throttle while accelerating yielded the best economy.
    That was because of volumetric efficiency.
    Getting up to speed faster uses less fuel that drawing it out over a longer period.
    MilkyJay, Dave_in_AZ and Lepton1 Thank this.
  5. Aradrox
    900
    622
    Jan 21, 2016
    You might be right just what I have been told to do and with no intiment k owledge my self... Either way no matter how I run this truck 7.1 it is....
    But you must admit engines are vastly different than they were "many years ago" and that study may not be accurate any longer
    Food for thought
    Dave_in_AZ, fargonaz and Bean Jr. Thank this.
  6. Moosetek13
    14,811
    18,695
    Nov 1, 2010
    Burnsville, MN
    Engines may be different in some ways, but physics is still the same.
    The same fact applies. If you can achieve a higher density in the fuel/air ratio more power is produced with less wasted fuel in the process.
    The higher pressure during combustion burns more of the fuel.
    It is less important with a turbo, but the concept is still valid.
    Where the newer engines have the real advantage of over the older isn't, I think, in the engine itself.
    It is the fuel and computer systems.
    Maintaining the ideal fuel/air ratio (along with volumetric efficiency) in all operating conditions are probably the most important things in getting both the most power and best fuel economy.
    That is why there have been such cool things as variable valve timing, and now even variable cylinder compression.
    Back in the day there was even the stratified charge engine. I'm not sure if that tech is still being used today.
    But I had a Honda CRX that got 52 MPG on the highway - back in the mid 80's! It used that type of engine.
    No computers, no turbo, no fuel injection either.
    If they could achieve 52 MPG using only a carburetor, even in a 2 seater, 30 YEARS ago...
    Where have their heads been since?
    Do you see anything close to that today, even with all the fancy computers and injection systems?
    Even in a tiny 2 seater, unless it is a hybrid?
    swervyjoe and mxpx148 Thank this.
  7. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    Ride the low RPM side of the highest gear you can get.
    Keep it around 60 on the freeway.
    Pull empty trailers exclusively.
    Don't drive at all.
    BB203, Dave_in_AZ, RedRover and 5 others Thank this.
  8. Moosetek13
    14,811
    18,695
    Nov 1, 2010
    Burnsville, MN
    I mean... Just GRASP it.
    52 miles per gallon!
    With no fuel injection or computer control or variable valve timing, or running off batteries that you have to recharge.
    KillingTime Thanks this.
  9. Moosetek13
    14,811
    18,695
    Nov 1, 2010
    Burnsville, MN
    Is it all about emissions?
    We have to make cleaner burning engines?
    But, doesn't burning more of the fuel in the combustion process also create less emissions - because there is less unburned fuel?
    Would not an engine producing 52 MPG be creating less emissions than an engine producing 10 MPG?
    (Everything else being equal, of course.)
    Maybe I'm a bit slow about these things, but it seems to me that the auto industry has gone very far backwards from my Honda CRX days.
    Dan.S Thanks this.
  10. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Convert that 9spd to a 13spd.
    Dave_in_AZ, RedRover, misterG and 3 others Thank this.
  11. Aradrox
    900
    622
    Jan 21, 2016
    There are a few diesel cars that can get that aswell
