How to handle a steer tire blowout
Discussion in 'Experienced Truckers' Advice' started by Lepton1, Nov 29, 2017.
  1. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I've posted a link to a YouTube video that should be required viewing for all truck drivers, newbie or experienced. It should be required viewing for ALL drivers.
    Notice that Benny Parsons said that the WORST thing you can do with a steer tire blowout is hit the brakes hard. Bear THIS in mind as I make another VERY important point.
    It takes about half a second to PERCEIVE anything and have the brain process it. It takes ANOTHER half second for you to react, like hitting the brakes. That's a real good reason not to tailgate, but this thread is about how to handle a steer tire blowout.
    The following video is how it IS NOT to be done. About 14 seconds into the video you can see the steer tire blowout happen, it looks like white smoke from a shotgun, or a shaped charge. THEN notice it take about one second before the driver does the WRONG thing and hits the brakes.
    Three seconds later the driver is dead.
    Almost two years ago I was following a 4 wheeler that had a steer tire blowout, on I-70 just west of Limon, CO. The driver hit the brakes. Three people in the car. The driver and a passenger sleeping in the back seat weren't wearing seat belts. They were ejected when the car rolled four times. The passenger in the front seat was wearing his seat belt. He likely had a broken back, but was walking. The driver was ejected downward and the car rolled on top of him. He was life flighted out with internal injuries and too many broken bones to count.
    The young lady sleeping in the back seat was 80' beyond the car. Broken back. Broken legs.
    Do NOT hit your breaks.
  3. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    I was taught a long time ago to always have a out, if you have to go off the road do it in a straight line so you do not tip over, you go off the pavement you going to be sinking unevenly so hold on, it is going to be a rough ride, but with power steering you do not feel the road as good anymore, still get both hands on that steering wheel, keep it straight as possible, might have to hit throttle a bit to do, which hitting throttle will take some of the pressure off the front wheel, but in little movements find a landing spot, then go wipe.
    Rollr4872, csmith1281, tinytim and 2 others Thank this.
  4. pmdriver
    2,338
    3,503
    Nov 14, 2017
    I almost forgot this one but get a pair of silk gloves and on your pretrip go over the whole front tires, inside and out side, a broken chord will snag that silk and let you know before it becomes big trouble.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Every time I hop out of the truck I take a quick look at the steers. Doing pre trips I spend more time checking steers than anything else.
    Slip seating and in the oilfield I just wouldn't feel right leaving the yard without a proper look see.
    csmith1281 and Lepton1 Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I have actually run off in the rain a time or two. That big truck fell into someone's lawn and dropped like a foot plus into that mud and grass. Threw it all sky high when I slammed the power down to the floor and held the wheel steady forward. The left hand drives stayed on the pavement and thankfully it was enough to maintain the rig as the embankment came up rather fast. (That was a potentially lethal problem that needed solving as the last few grains of sand runs out of the hourglass awful fast...) I horsed it back onto the pavement with a really quick movement of the wheel that lasted just a little bit. The trailer shook and then followed me over back to the left.
    It worked out that time. But that man when he wakes up in the morning and see he has no front yard probably hopped up and down for weeks. Still is and I wont blame him one bit. That is one reason I don't buy houses that close to a roadway. heh.
    To end the story, the most important thing is to hold on to that steering and make very small inputs slowly one at a time giving her time to follow through. She'll do it for you if at all possible. You can deal with the damage later if any.
    csmith1281, tinytim and Lepton1 Thank this.
  7. HighwayD
    HighwayD Light Load Member
    58
    61
    Nov 15, 2017
    Pennsylvania
    Excellent advice. I NEVER heard of this. Thank you.
    gntorres61, csmith1281 and x1Heavy Thank this.
  8. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    usually if a tire is so bad you got metal coming out, it's OOS. And even better if you examine your tires several times a day and night you will see a problem developing long before it gets that bad. When I started it was necessary to make tire stops every 80 miles or so if I remember right. Right about that much. Then again, they were pretty easy to change back then.
    Dan.S and csmith1281 Thank this.
  9. HighwayD
    58
    61
    Nov 15, 2017
    Pennsylvania
    Thanks for the extra info, heavy. Experienced professionals like you and many others in this forum provide young bucks like me with much needed schooling.
    csmith1281 Thanks this.
  10. KillingTime
    KillingTime Road Train Member
    3,865
    61,880
    Mar 26, 2016
    Rockland, Maine
    Didn't watch the vid *disclaimer* - but I can tell you what happens simply by understanding basic physics.
    Steer blows.
    Slam brakes.
    You're already off balance.
    Lock up.
    Truck dives, awkwardly.
    Load is pitched.
    Falls on top of you.
    Game over.
    Be cool. There's a 40k lb (ish) gun pointed at the back of your head all the time, fellas. More than that for some of us.
    Dan.S, tinytim and Lepton1 Thank this.
  11. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Erm I appreciate it but keep in mind, I am only one me and I do tend to get... "Lunch countery" sometimes to use a bad term. with stories that have a grain of truth somewhere. And a little bit of ... drama I suppose.
    I do remind you that the life I had starting off, with trainers punching, shoving and so forth is probably not a acceptable life to you young ones today. So.. er.. I guess Im history. But its what I had. Not what you, you and you in the back had necessarily.
    csmith1281 and Brettj3876 Thank this.
