How to handle nails in tires?
Discussion in 'Questions From New Drivers' started by GiantBeard, Apr 30, 2016.
  1. GiantBeard
    GiantBeard Medium Load Member
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    At some point between picking up a load and stopping for fuel I had a tire go flat. I cursed the service center and blamed their patch, which, as it turned out, a nail had gone right through their patch. Got it fixed up and headed out. (The tech said million to one odds of that.)
    Now I get to my stop, I check all my tires real good, picking out the rocks and eyeballing them closely.
    I found three more nails in two of my drive tires! One on the left and two on the right, thrid axle.
    Do I leave them in or pull them out? Do I have a service tech do it for me? Never had a nail in any tire of anything that I've driven for over 10 years and now they just pop up like zits on a kids face!
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Soap them, and see if they are leaking. Let a tech pull them, or pull them yourself when you're parked outside the shop.
  4. Going Long
    Going Long Light Load Member
    109
    87
    Aug 19, 2009
    Maryland
    If the head of the nail is in a groove you will be ok for a bit.
    But follow the above advice to be safe.
    GiantBeard Thanks this.
  5. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    If you drive thru construction zones you could be picking up the nails from that or if the customer has a bad lot.
  6. GiantBeard
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    The heads are gone, just gnarled shafts. One is thick, like a deck nail, the others are thin, almost like finishing nails.
    I'm starting to suspect that we need a magnetic rake to clean up pallet debris on the farm.
    It doesn't help that the 'burn pile' is in the driveway... Smh...
    Lepton1 and JReding Thank this.
  7. Accidental Trucker
    Accidental Trucker Road Train Member
    3,397
    7,556
    Jun 4, 2015
    Yeah, delivered at a farm one time and they had just graded their lot, including the burn pile. 8 nails from that little adventure......
  8. northernhopper
    northernhopper Light Load Member
    260
    367
    Mar 15, 2015
    isanti mn
    Go to napa or oriellys and buy a good plug kit. Plug last just fine in nail sized holes. Dont listen to the naysayers. 25-30 buck and 15 mins you can fix several. You do need to cut the plug off flush when you are done so keep a razor blade also. Buy the sturdy tools not the small cheap handled ones. They break pretty easy
    Dave_in_AZ and GiantBeard Thank this.
  9. Going Long
    109
    87
    Aug 19, 2009
    Maryland
    I have run tires for months with nails in them,just monitor the air pressure.
    I pulled a bolt out the other day,have no idea where it came from.
    Lucky me it was in the meat part of the tread.
    Always carry a plug kit,easy to use and will save you $$$.
  10. EZ Money
    EZ Money Road Train Member
    3 nails for me in the last 2 weeks....One was a 16 penny in a steer tire!
    That was 600 bucks for a new steer....not patching that for steering use!
    We patched it and saved it for a trailer tire....
    SLANT6, Pmracing, mrg1 and 1 other person Thank this.
  11. GiantBeard
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    Thanks for all the advice!
    Looks like I'm off to buy a plug kit, not the cheap-o brand, and to keep an eye on the tire pressure.
    ....I'm also going to raise hell about cleaning up the driveway. I found dozens of nails, of the same types in my tires, just within feet of my truck....
    They're going to have to move the camp fire somewhere else!
    Lepton1 and Pmracing Thank this.
