How to have power windows with the key switch off?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OTR48+C, Sep 16, 2018.
  1. OTR48+C
    OTR48+C Bobtail Member
    45
    10
    Dec 13, 2010
    Kenworth T680
    Does anyone know the fuses ID# to jump to power to be able to have power windows when the key switch is off?
    Thank you,
  3. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    You ask for too much. This would be like having a super power
  4. The reason for no power to windows when key is off. Is security. What prevents someone from slipping a wire down onto a window button when truck is parked.
    omarbaca Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,717
    9,023
    Jul 12, 2017
    Your sure?? Power door locks are almost always constant power. What's the difference between windows and doors? If your a thief ,your gonna find a way. If any reason it should be for safety for getting out during an emergency.
  6. Hulld
    Hulld Road Train Member
    2,883
    6,567
    Oct 19, 2015
    Upstate NY
    My Freightliner power windows work with the ignition off.
  7. Cattleman84
    Cattleman84 Road Train Member
    9,919
    70,763
    Nov 1, 2017
    The Sticks, Idaho
    @OTR48+C
    Its easy to figure out... Buy a test light from the truck stop for like $10. The with the key off, clip the one end of test light to a good ground (door frame or the like) then start looking for a live circuit. Once you find it jump power from constant power source to fuse for windows.
    If your not sure which is for windows... With key on check by pulling one fuse at a time and trying to operate windows, when the windows quit working you found the right one.
  8. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    That won't work that will power up the key on side of the ignition just like his key was on ....unless he cuts the power to that fuse so it doesn't back feed
    mslashbar and Cattleman84 Thank this.
  9. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    Why do you want your windows to work with the key off?
  10. OTR48+C
    45
    10
    Dec 13, 2010
    I don't want to turn the key on all the time just to put my windows down or up.
