How to identify if a transmission is double OD
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jun 17, 2022.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,307
    1,679
    Dec 4, 2019
    I’ve got a 15 against the dash in my 379 Pete dump truck. I think it’s got 4:25 rears but I’m gonna bet it’ll run over 100. I bought it back in December, from north central KS and drove it back to Joplin Mo for the night. In the first hour I could see the old truck was gonna do fine and then I decided to air it out. Drove it around 85-90mph for hundreds of miles. I’ve seen and read discussions on hear about the OD’s/ DOD’s and the fact that the gears being flipped, doesn’t always mean it’s a DOD. Explain and let me know how to identify.
  3. roundhouse
    roundhouse Road Train Member
    3,179
    7,232
    Jul 11, 2018
    Does the trans have a data plate ?
    Figuring the axle gearing is easy.
    Jack up , get both wheels off the ground .
    Make a chalk mark on the wheel and one in the driveshaft .
    Turn the wheel and count the rotations of the shaft .
    baha Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    That's why most have the deep reduction lower gears, so when you are loaded and pointed up a hill you can still get it moving and most have the .73 over drive? A 10 speed with the back box flipped around won't get started loaded on any kind of hill! But will get you a speeding ticket with out trying hard.
    Jammer' Thanks this.
  5. AModelCat
    160,447
    Need the model number. You could get an overdrive 15 with the stick against the dash or towards the back wall. All depends on the top cover.
    mile marker 27 Thanks this.
  6. jamespmack
    215,913
    Pretty certain no 15 speed eaton was avaliable with 2 overdrive gears. Single od only.
    BoxCarKidd Thanks this.
  7. AModelCat
    160,447
    I'm thinking you're probably correct. OD in the main box, deep reduction, low range and high range (direct) in the back box.
    At least that's how mine is.
    jamespmack and mile marker 27 Thank this.
  8. mile marker 27
    1,307
    1,679
    Dec 4, 2019
    .......so the only thing with double OD’s would have been a 13?
  9. jamespmack
    215,913
    Just to be clear, I have about zero experience with a 8ll or 15 speed.
    Eaton Rtoo,Rtlo would be only double overdrive trans I'm aware of. 13,or18 speeds.
    Maybe be others, will need someone else to answer that.
    mile marker 27 and spsauerland Thank this.
  10. SmallPackage
    5,524
    17,598
    Dec 20, 2019
    Marion Texas
    No 15 double O’s from Eaton factory but a 15 can be modified to be double o by the right shop. Has been done many times but they can be very noisy on the top end. More so then the old 9513’s that howl in od around 60-65 mph.
  11. jamespmack
    215,913
    Had a 9513 all new parts, in 9th od overdrive rear sound like a bucket of bolts. Quiet in every other gear. Straight cut gears are loud!
    I feel I have heard that. But would it not be huge ratio jumps?
