How To Idle A 2019 Freightliner Prime Inc?
Discussion in 'Freightliner Forum' started by Cassini, May 7, 2019.
  1. Cassini
    Cassini Bobtail Member
    7
    5
    Jul 23, 2018
    Hey guys, I have a 1500 watt convection oven that I can only use on my inverter(1500 watt) when the truck is idling. (APU isn't enough power)
    The thing is, I have to keep hitting the gas pedal to keep the truck running, but after doing that three times, the truck will turn off without giving me a shutdown warning.
    Our road assist guy says that I can enable the high idle by "revving it up a little and setting the cruise" but the cruise control can't be enabled unless I'm at 10+mph. Could someone help me out here? Thanks
  3. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Trick the truck into thinking you’re in stop and go traffic. Release brakes put in gear then put back in neutral and park brakes. Hopefully it works I’m just throwing ideas.
    D.Tibbitt and Cassini Thank this.
  4. 201
    201 Road Train Member
    12,459
    25,476
    Apr 16, 2014
    high plains colorado
    OMG, such problems for the modern day truck driver, truck won't idle, can't use the stove, or TV and hot tub for that matter. We used to warm a can of beans on the exhaust manifold,,,:p times sure have changed.
    truckdriver31, mhyn, Cassini and 6 others Thank this.
  5. Cassini
    7
    5
    Jul 23, 2018
    Yes, they have changed, now we use the bunk heater to warm a can of beans. :rolleyes:
    Ffx95, Working2party, 201 and 2 others Thank this.
  6. D.Tibbitt
    151,897
    Cruise control should be able to set .. Turn it on and press set.. Now press the fuel pedal.. If it doesnt rev up then it is set... Find the tempersture censor and put a hand warmer on it so it glitches out the sensor to think that its to hot.. Most trucks wont idle between 30 degrees and 70 degress.. If above or below then it will stay idling.. Depends how the computer is set up... Or chock ur wheels and release breaks that might work as well
    x1Heavy and Cassini Thank this.
  7. D.Tibbitt
    151,897
    The main this is.. The way auto shutdown works is it reads the ecm.. And if nothing has changed in the ecm and the shutdown isnt being overridden then its going to shutdown the truck... Cruise control usually overrides that process so it never shutsdown.. Thats why when the old timers say to put a brick on the fuel pedal it doesnt work on todays trucks because if the rpms dont flucuate and no process changes in the ecm ( parking breaks set or released, fuel pedal revved, clutch pedal depressed,etc) then it will shutdown the truck... I made when i was up in minnesota it was -70 wind chill my company disabled high idle which in those temepratures i couldnt keep any heat so i pissed in a gstorade bottle and put the lid on it (very important) and i was able to wedge it in between the fuel pedal and the steering column .. But i was able to set it in a way the liquid if i moved the bottle it would keep thr fuel pedal moving up and down slightly incresing and decresing the rpms by 5 or 10 which isnt much but enough to trick the truck and the ecm thinking somebody was pressing the fuel pedal.. It worked for about 3 hours before it got unwedged and fell on the floor , going back to what i said about making sure the lid is on tight lol
    Cassini Thanks this.
  8. Western flyer
    Western flyer Road Train Member
    2,807
    6,796
    Mar 13, 2014
    Release the tractor brakes.
    Leave the trailer brakes set.
    Works on ours.
    You can idle all night.
  9. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Prime trucks will usually shut off after 5 minutes even if you are in gear and have your foot on the service brake.... Makes your head asplode when the truck shuts off right before traffic starts moving, what a joke.
    Maybe you can fit a bigger alternator on the APU, get a couple more batteries, buy a generator, bribe a shop person to allow idle (unlikely), try asking your FM to give the shop ok to change the ide settings, or get a smaller oven.
    They don't have the trucks setup to ide between certain ambient temperatures any more so you can't "trick" a sensor.
  10. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Wrap your food in aluminum foil(2 or 3 wrappings)place it on the exhaust manifold and by the time you get to where you're going, voila', hot food. Just joking, if you put a stick between the seat and the pedal, won't that work?
  11. TheMofo
    TheMofo Bobtail Member
    12
    19
    Apr 21, 2019
    For a 1500W microwave you would want at least a 2500W inverter, preferably 3000W constant.
