How to idle on high RPM Kenworth T680 2016
Discussion in 'Werner' started by Big Viper, Jan 30, 2019.
  1. Big Viper
    Big Viper Bobtail Member
    Chicago
    I own a Kenworth T680 that my company bought from Werner 6 months ago and I don’t know how to idle at high RPM’s.
    I’ve tried to turn ON the cruise control and than SET button but is not working it stays at 700 RPM’s. Tried also with truck and trailer breaks SET still the same..
    Please help.
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Ecm is probably programmed that way . You may need to visit dealer to get it raised... Werner’s policy is to save fuel they aren’t concerned with longevity of engine .
    Matt43324, Tombstone69 and Big Viper Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    In the old days you would be at parked, idle nuetral and then turn on the crusie control, and bump the set speed and every bump you got 50 RPM. Max for me was 1500. bump. And it will hold it all night or until it runs out of fuel if need be in cold weather like this.
  5. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    It would be on the build sheet, if you have it, if you don't, give the vin to the dealer and they'll send it to you.
  6. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    If you absolutely have to idle find a stick that fits between the seat and the fuel pedal and move your seat up to where you want it to idle.I actually have a tool,I think it was made in the 50s, it has a pad on each end adjusts in the center. Also has a hook for the clutch pedal, so you can adjust the clutch.
    ColoradoLinehaul and 201 Thank this.
  7. RockinChair
    RockinChair Road Train Member
    5,121
    12,948
    Feb 19, 2012
    CC, TX
    After turning the cruise switch ON, you may have to hit the SET switch and then use RESUME to increase the RPMs. I've driven a few trucks that were that way.
    Also, make sure your clutch pedal position sensor isn't preventing you from idling up.
    blairandgretchen Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,564
    13,288
    Jul 6, 2009
    It's probably a werner spec. You can have the ecm stripped of passwords werner may have set and have the computer opened up. Don't know what the cost is these days. I paid $150 on a 05 w900 at a cummins shop in Dallas. They ran a password software to delete the password. Then they reflashed the ecm. There was no governor anything after that.
    Best money you'll ever spend. More power and better economy having that thing run on it's own parameters instead of company parameters.
    Dexterr and blairandgretchen Thank this.
  9. 201
    201 Road Train Member
    12,407
    25,365
    Apr 16, 2014
    high plains colorado
    I think this is a silly post, jam a stick on the pedal, not rocket science,,,
  10. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Looks like Werner took off that option. If you’re a company driver then don’t worry about it they want to ruin their truck fine.
    Matt43324 Thanks this.
  11. Kyle G.
    Kyle G. Road Train Member
    3,868
    20,341
    Jan 23, 2016
    Eastern Iowa
    You may have to push the throttle down to your desired rpm then hit the set button.
