How to Increase the Jake Brake Power?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Mar 21, 2019.
  1. PE_T
    PE_T Road Train Member
    So I drove an automatic 2015 Freightliner Cascadia DD15 (mine is a 2014 and manual), and I noticed the jake brake was much stronger. Is it possible to make mine stronger? I’m guessing the dealer will have to plug in the computer?
  3. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    The only way I can think of is to run the overhead,
    I don’t know of a setting in the software for the Jake Brake Power.
    magoo68 and PE_T Thank this.
  4. Freightliner Classic
    Freightliner Classic Light Load Member
    108
    98
    Dec 17, 2018
    Rome GA
    Run over head the only way. Motors thease day dont have powerful jakes like the old cats and detriots
    PE_T Thanks this.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Jakes today are a lot stronger than they were 2 decades ago. Noise doesn't equal powerful. VGT turbo will always have a stronger jake than a big old school turbo. The ISX and DD15 have very strong jakes
    magoo68 Thanks this.
  6. Antinomian
    Antinomian Road Train Member
    2,136
    3,389
    Feb 17, 2013
    Here is the diagnostic bulletin from Detroit. I'm in the middle of having my jakes repaired and it's getting expensive. Turns out I have 4 out of 6 actuator pins seized. Those jake rockers are $250 each.
    Poor Engine Brake Performance
    spsauerland and PE_T Thank this.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Put it on the number three setting
    TheBaron97, PE_T and 062 Thank this.
  8. 062
    062 Road Train Member
    6,275
    33,779
    Oct 20, 2013
    Hmm... maybe the shoes are wore out.
    PE_T and Bakerman Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    I don't know about power.
    If I want power, I just redline the jakes and keep a eye on that oil temp, pressure and Mr Pyrometer. If it's a newer engine I'll add 10% beyond redline for a few moments if I have to.
    Our engines have been stuck in the 500 to 600 range. Never more than that. We can absolutely run 1000-1500 horse, 2400 torque etc. With the idea that the more you have on hand the less fuel you are going to burn to do the work, say lifting 80000 pounds all the way up and over Wolf Creek Pass in Co. However the companies insist on buying anemic engines and really good engines have gone into history. A memory. Some of those great old engines should have burned up proper with me and my very heavy loads. But they held up with two exceptions in my lifetime. What engines... awesome.
    Today's engines do not generate that much motivation. They are all the same. Buried in Emissions (Or drowned rather) and have no balls to do anything but whine and then overheat or throw codes.
    I better stop talking. It's one of my hot buttons to have engines that are not engines worthy of the name.
    A5¢, Dino soar and PE_T Thank this.
  10. PE_T
    Hahaha. I am aware of it.
    062, Bakerman and x1Heavy Thank this.
  11. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Just making sure
    062 and PE_T Thank this.
