how to keep a 2015 cascadia idling
Discussion in 'Questions From New Drivers' started by selinrosa, Sep 12, 2020.
  1. selinrosa
    selinrosa Light Load Member
    55
    18
    Aug 30, 2020
    my engine automatically shut off after 5 min when the truck is not moving. It's so frustrating for a driver who can't survive without AC in summer.
    Is there an effective way to keep the truck idling?
  3. AModelCat
    159,394
    Go to dealer, get idle shutdown turned off.
  4. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Doubt they will do that for a company truck?
  5. AModelCat
    159,394
    OP has another thread going where they said they're an O/O.
    Speed_Drums, Dave_in_AZ and rachi Thank this.
  6. selinrosa
    55
    18
    Aug 30, 2020
    Thanks. Do you have idea how much it will cost to do the trick?
  7. rachi
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Alot of the cascadia's of that year have a heat sensor on the bottom or on the top of the driver side mirror. Some guys would wrap a small thermal patch heat around the sensor area to keep it hot and then truck will idle if your lucky!
    Speed_Drums Thanks this.
  8. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    Does it do this even after you put it in a high idle?
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    And some time later the OP will start a new thread.
    "Engine check light on-derated because off emissions faults"
  10. selinrosa
    55
    18
    Aug 30, 2020
    you know what is wired i came across this trick when browsing some youtube videos, but couldn't locate the temp sensor under either side of the mirror.
    rachi Thanks this.
  11. selinrosa
    55
    18
    Aug 30, 2020
    thanks for the warning. but how do truckers rest in summer without AC?
    farmerjohn64 Thanks this.
