How to know if you need chains.
Discussion in 'Experienced Truckers' Advice' started by zoodayz, Jan 1, 2024.
  1. zoodayz
    zoodayz Bobtail Member
    14
    7
    Sep 2, 2013
    I grew up out west and if I remember right there use to be signs that said if you need to chain up?
    is this correct? its been some time since iv been out west.
    Also what is the best source of information to see if chains are required?
    Thanks all for the help
    /peace
    zoodayz
  3. tscottme
    tscottme Road Train Member
    Oregon has those signs. I don't remember seeing signs like that in other states. The most common signs are "Chains required to be carried from Nov to April" or something. In the front of the Motor Carrier Road Atlas is a sourced for road conditions for each state. Many states make the same info available somewhere online. On Oregon's Tripcheck.com it will say "chains required between Mile Marker X and Mile marker Y. Unfortunately it is listed in a long list of notices and not with some symbol on the map that is much easier to see when you need it.
  4. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,014
    2,086
    Dec 15, 2021
  5. DonRobbie
    DonRobbie Road Train Member
    1,080
    2,687
    Nov 26, 2005
    Midwest
    I know Colorado has signs with lights on them that will be flashing if chaining is required.
  6. Long FLD
    Long FLD Road Train Member
    12,885
    53,966
    Mar 4, 2015
    There will be signs and/or overhead reader boards telling you if chains are required if you’re on a major route. About the only sign I can recall that isn’t cut and dry is the Idaho side of Lost Trail. The sign just says chains advised if road is snow covered or icy and they let that amber light flash all winter long until the snow melts.
    2Tap, Oxbow and tscottme Thank this.
  7. Animosus
    Animosus Heavy Load Member
    732
    2,906
    Dec 7, 2015
    SE Wyoming
  8. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,548
    2,702
    Jan 7, 2023
    In CA and WA, usually a guy wearing a uniform and a "Smokey Bear" hat tells you to pull over and hang iron. Back in my day, OR left it completely up to the driver, and with having grown up in a great-lakes snowbelt and having a truck with deep-siping and lugs on all my drives, I'd often head to OR to cross the mountains chain-free rather than deal with them on Snoqualmie or Donner.
  9. Rugerfan
    Rugerfan Road Train Member
    7,740
    39,657
    May 3, 2011
    Redding,CA
    Oregon is very weird with chains. They only tell you online of chains are required, but no one is there at the pass to tell you. Sometimes it’s not currently snowing, but the pass is messed up but you can’t check it from the bottom of the pass with no phone service. They don’t do a good job.
    cke, OLDSKOOLERnWV and beastr123 Thank this.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,985
    19,037
    Nov 1, 2010
    Burnsville, MN
    Check out SafeTravelUSA dot com.
    The one stop shop for all the DOT websites for each state.
    silverspur and tscottme Thank this.
  11. Accidental Trucker
    Accidental Trucker Road Train Member
    3,439
    7,815
    Jun 4, 2015
    Do NOT count on others to tell you when you need chains. There are more than a few roads without warning systems (hwy 30 in SE Idaho is just one). Most of the time, authorities are nervous Nellies and put the chain sign up before it is needed. That’s no reason to put your life in the hands of some bureaucracy. Use the CB to talk to trucks coming your way. If the road is icy, or could be icy, hang the iron.
