How to locate part # ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Crazy Alex, May 4, 2017.
  1. Crazy Alex
    Crazy Alex Light Load Member
    161
    46
    Dec 1, 2012
    Here n there
    Need to replace king pins on my 2002 Volvo 770. Shop wants $419 for the set (right and left).I think I can find cheaper on line,but I need to know the part # to search for. How do I find it?
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    Call a Volvo Stealership and ask them for the part number, then Google the part number and see what happens.
  4. Crazy Alex
    161
    46
    Dec 1, 2012
    Here n there
    They don't like to give out that info...
  5. boneebone
    2,296
    2,367
    Mar 13, 2009
    I don't have a problem with my local Volvo Stealership giving part numbers.
    If you like, give me the last six numbers of your V.I.N. and I'll get the part number for you.
  6. JReding
    JReding Road Train Member
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,471
    6,508
    Aug 26, 2014
    Get the number off of the front axle tag, located on the beam, and call your local brake and suspension parts supplier. I do not like anything with nylon.
  8. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    If it is Stemco kit then they are probably going to run about that much. They used to be cheaper but went up in price a while back.
    If you look dead center of your axle it should have a metal plate with your model/make of axle. Here is the chart to tell you which kit you need. http://www.stemco.com/f/qbin/01 577 0001 QWIK Kit.pdf
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    The best way is the axle tag, but if that leads to problems try www.cumberlandtruck.com/ They are a parts house and own Volvo dealerships.
