How to lower blood pressure before physical
Discussion in 'Questions From New Drivers' started by LakeErieHillbilly, Feb 16, 2022.
  1. LakeErieHillbilly
    LakeErieHillbilly Light Load Member
    74
    18
    Feb 5, 2012
    Northern Ohio
    Going to have my DOT physical in 2 weeks. BP is pushing high range 175ish. Not real huge but not a underwear model by any means. How can I get this lowered within the 2 weeks so I can pass the physical and keep the blood sugar under control, thanks.
    jethro712 Thanks this.
  3. Siinman
    Siinman Road Train Member
    5,455
    14,025
    Mar 5, 2017
    Kansas City, MO.
    Meds
    Concorde, Gabe85, GYPSY65 and 2 others Thank this.
  4. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Are you KIDDING someone? Anything over 149 is HUGE for "truck med cert approve plus" if any.. What is the "lower", the kidney one, the one, that can make you blind?
    If you are going to "lower" it, you will have to stay with it. What is your age, weight, exercise habits, if any, except lifting fork?
    I'm more than sure you have known the problem, what are you taking? If not taking anything still, ask your doctor Cozaar, or at least Lasartan its generic substitude..100 mills, it relaxes your vessel walls to lower the pressure, but man.. Wish you luck.
    ProfessionalNoticer Thanks this.
  5. jethro712
    jethro712 Medium Load Member
    604
    6,035
    Aug 31, 2014
    lifestyle change. foods that harm, foods that heal; by reader digest. read it. everything we eat either feeds disease or fights it.
    moderate exercise, even walking. a mile a day helps. if your on fb, daily natural medicines/remedies may be a good guide as well. good luck.
    Snow Hater Thanks this.
  6. LakeErieHillbilly
    74
    18
    Feb 5, 2012
    Northern Ohio
    Before people put me into the ground 6 feet deep I should clarify better. That was my high reading tonight at Walmart. Low was 163. Time I can get it down to the 140ish range but I do have more higher reading now. As a change is needed of course, Im looking to pass that DOT in 2 weeks. Been 9 years since I drove last. Needing crash course ideas for next two weeks to get that decent reading. Im 6`2 and 310lbs.
    Gabe85 and Chinatown Thank this.
  7. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    Absolutely no caffeine. Drink plenty of water. Beet juice. There are some breathing exercises on YouTube.
    But you really need to see a Doctor. There is a reason they call High Blood Pressure the silent killer.
    Val_Caldera, jsnell, Gabe85 and 4 others Thank this.
  8. nredfor88
    nredfor88 Road Train Member
    1,801
    6,098
    Sep 26, 2019
    USA
    You can’t lower it from that level in two weeks without meds. Now if you had the better part of a year, vegetables and exercise would likely do the trick.
    Trucker61016, ncmickey, Gabe85 and 2 others Thank this.
  9. tscottme
    tscottme Road Train Member
    You have a long way to go if you are trying for a 2 year card. I think it has to be at 140/90 or below for the 2 year.
    Here's a YT video for a temporary drop in BP a few minutes before getting the test.
    RepoweredRookie and tarmadilo Thank this.
  10. Brandt
    Brandt Road Train Member
    4,606
    6,326
    Sep 17, 2012
    If you can't get it down. They would probably give you meds and a 3 month medical card. If it's new medical card they could make you wait to get under better control.
  11. tscottme
    Weight loss gives you the biggest bang for your buck on lowering BP and probably sugar also. Also stop drinking anything but water and no caffeine.
    Dave_in_AZ and Ttr5589 Thank this.
