How to make the clutch pedal softer?
Discussion in 'Freightliner Forum' started by bigtire, Oct 10, 2012.
  1. bigtire
    bigtire Light Load Member
    117
    13
    Feb 19, 2012
    Las Vegas, Nevada
    I have a Columbia 2006 dd 14 l, Eaton fuller 10 speed. The clutch pedal is very heavy to press. My wife can't drive it. Is there a way to make the pedal softer? This is the problem that is pushing me to buy a truck with a ultrashift.
  3. GAlanFink
    GAlanFink Medium Load Member
    334
    271
    May 8, 2012
    Bucks County, PA
    The only time I use the clutch is starting out and, in your wife's case, if she is unable to depress the clutch at all, she either needs to exercise a tad more or you can have your throw out bearing spring(s) tension lowered slightly at some cost, I'm sure.
    I can appreciate the aggravation of a hard clutch though having had to run trash pickup for WM some years ago. That constant clutching can tear your left knee up.
    If she can depress the clutch but just doesn't have the strength for the constant clutching involved with standard shifting, she might want to learn how to use the RPM's to find the next 'slot'. Usually, it's somewhere around 400 rpm up or down and, if climbing or going down a grade, simply skip a gear to 'keep up' with vehicle speed changes.
    On a positive note, your wife will never snap a drive shaft because the vehicle speed exceeded or dropped out of range of the gear she is going into.
  4. BigJim1937
    BigJim1937 Medium Load Member
    303
    135
    Mar 27, 2012
    Fargo,ND
    well you could try a small piece of foam on the pedal. JOKING There is an adjustment, check with a good service shop and they can fix that for you. My wife has been driving longer than I have the clutch pedal on her truck looks like it did when it came out of the factory.
    bullhaulerswife Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    Thete are no springs on the throw out bearing.
    The stiffness is in the clutch disc. It probably has a 2300 pound disc. U can replace it with a 1800 pound disc. World of diference in the pedal.
    Clutch pressure plate i mean
    NYROADIE and bullhaulerswife Thank this.
  6. BigJim1937
    303
    135
    Mar 27, 2012
    Fargo,ND
    Well last time I checked there were return springs otherwise how the hell would it move back. just sayin
  7. Worthken
    Worthken Light Load Member
    265
    83
    Jun 2, 2012
    Delmas South Africa
    Have a look at the linkages. There is a way to set it up to get the maximum leverage out of the pedal. The way the linkage connects at the gearbaox also plays a role, a longer arm on the clutch fork shaft can also make a differance.
  8. snowwy
    20,590
    13,308
    Jul 6, 2009
    the clutch fork is how the hell it moves back.
  9. Real Deal
    Real Deal Medium Load Member
    468
    230
    May 29, 2012
    Saint George UT
    Look at the clutch pedal linkage.It should have a spring inside of another spring that returns the pedal.Take it down to a single.If it is already a single replace it with a softer one. And don't listen to about 95% of advice on here.
  10. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Or you could change your truck to an air assisted clutch.:biggrin_255:
    Soft as butter on a hot day.
  11. snowwy
    20,590
    13,308
    Jul 6, 2009
    My clutch pedal dont have springs
    Its all linkage
