How to open tank fairings on a KW T660 for battery check
Discussion in 'Ask An Owner Operator' started by ibtruckin304, Jan 21, 2016.
  1. ibtruckin304
    ibtruckin304 Light Load Member
    50
    10
    Dec 13, 2011
    Huntington,Wv
    I am trying to access my battery box and ive tried to find a latch or lever under neath but no luck so far, anyone familiar with this?
  3. Coyote302
    Coyote302 Light Load Member
    86
    71
    May 9, 2014
    LA(lower Alabama)
    There is no latch... 3 bolts in each step on drivers side, I think it's 17mm.
    ibtruckin304 and Cottonmouth85 Thank this.
  4. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    That'll do it. Open hood, remove bolts. Box underneath. Make sure you lube em when you put it back together.
    ibtruckin304 and Coyote302 Thank this.
  5. ibtruckin304
    50
    10
    Dec 13, 2011
    Huntington,Wv
    I appreciate the info drivers be safe out there in this adverse weather,and thanks again
    Cottonmouth85 Thanks this.
