How to override idle shutdown in Freightliner Cascadia 2022
Discussion in 'Questions From New Drivers' started by xzmpt, Dec 18, 2024.
  1. xzmpt
    xzmpt Light Load Member
    91
    82
    Nov 22, 2022
    I just got assigned another truck because my Kenworth t680 has been in the shop for 2 weeks. They’re trying to fix an adaptive cruse fault issue. I was assigned a 2022 Cascadia. And there seems to be no way for me to idle over night. I tried upping the RPM but the truck still shuts off. I am currently bob tail. Are there any other options or am I just SOL? Anyone else have this truck, how do you handle it?
  3. 062
    062 Road Train Member
    6,275
    33,779
    Oct 20, 2013
    Depends on how the parameters are set. Some will shut down between a certain temp range.
    Some are set to shut down by a timer.
    nextgentrucker, TX2Day and xzmpt Thank this.
  4. BM 58
    BM 58 Road Train Member
    1,331
    4,559
    Jun 25, 2019
    If you are Bob tailing back against a curb and release the brakes. Idle up and go to sleep.
  5. xzmpt
    91
    82
    Nov 22, 2022
    There’s a 3 minute timer on it. This sucks. If I put something on the pedal to rev the rpm up to keep the truck going, is that the same as just using cruise control to rev the rpm up? I want to make sure I’m not poisoning myself or anything in a crazy.
    77fib77 Thanks this.
  6. xzmpt
    91
    82
    Nov 22, 2022
    I coincidentally brought this piece of metal from my old truck. To this day, I don’t know what it’s for but i used it in the past to bang my tandems when they were stuck. It’s about a foot long and maybe 5-7lbs. I leaned it against the pedal and the rpm is currently idling at 900. It’s been 10 minutes. Am I good to sleep like this? Want to make sure having the pedal constantly engaged isn’t poisoning me or anything.
  7. tscottme
    tscottme Road Train Member
    If this truck has a Qualcomm or messaging system plugged into the truck it is 99% certain it is recording & reporting idle time to the company. To keep idling it may require the RPMs vary during the countdown timer period. I've had some trucks that will shutdown no matter what you do, even while sitting in traffic.
  8. Moosetek13
    Moosetek13 Road Train Member
    14,812
    18,698
    Nov 1, 2010
    Burnsville, MN
    It won't poison you.
    In my last truck the Freightliner dealer set my (out of gear) idle to 875 because of a problem with top end lubrication. It was a directive from Freightliner.
    Only at that one dealer, though. It has been in a few times since to both Swift and Freightliner and they turned it back down to around 600.
    I guess not everyone gets the memo.
    I never had any luck with setting a higher idle propping something on the pedal, because the constant speed was always seen as a standard idle.
    But if it works for you, keep quiet about it and enjoy the freedom.
    xzmpt, 77fib77 and Flat Earth Trucker Thank this.
  9. xzmpt
    91
    82
    Nov 22, 2022
    Yea the truck eventually shut down after a while even when putting something on the pedal.
  10. xzmpt
    91
    82
    Nov 22, 2022
    The truck eventually still shut down after about an hour unfortunately.
  11. wulfman75
    wulfman75 Road Train Member
    2,314
    3,097
    Jul 15, 2010
    Athens, GA
    It's a cascadia. Does it have opti idle?
