how to physically check your brake pads and drums?
Discussion in 'Questions From New Drivers' started by DC843, Feb 1, 2016.
  1. DC843
    DC843 Medium Load Member
    672
    301
    Jul 4, 2015
    can anyone explain the method one would use for physically examining your brake pads and drums to make sure they are not getting close to failing? is there a way to do it if you have dust covers without taking the wheel off?
    ive been trying to find something about this online and all I can find info on doing the various brake tests, and not actually checking the brake themselves.
  3. truckingmechanic
    truckingmechanic Light Load Member
    63
    13
    Sep 4, 2015
    Go underneath and make sure neither is cracked and that you have enough brake pads left
    thejackal, bottomdumpin and ajohnson Thank this.
  4. ajohnson
    ajohnson Medium Load Member
    580
    1,368
    Jan 6, 2016
    chicago area
    Look on the inside of the wheel, should be pretty obvious. Do you have a cdl? This should be covered in training
  5. AnthonyM757
    AnthonyM757 Light Load Member
    203
    95
    Sep 13, 2015
    I've always went under the truck and and look at them under the wheel, and check for at least a quarter thick inch brake pads, make they are snug to the drum. And also see if the drum is not cracked or broken...
    DC843 and ajohnson Thank this.
  6. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    When press brake no stop need new brakes.
    dca, taxihacker66, finbyrd and 4 others Thank this.
  7. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
    Your going to open up a big can of worms. If you can see the bottom of brake shoe it should be about 9/16 thick. Use a 9/16 open end as a reference. That's a rough estimate
    Good luck
    DC843 Thanks this.
  8. DC843
    672
    301
    Jul 4, 2015
    i do but they never explained how to check them at the place i went to, just basically where they were.
  9. Moose1958
    Moose1958 Road Train Member
    15,259
    33,823
    Dec 17, 2010
    Williesburg, Virignia
    I am not sure if this will answer your question.
    mnmover Thanks this.
  10. ajohnson
    580
    1,368
    Jan 6, 2016
    chicago area
    Like everyone said, look at them, no cracks, nothing missing, and make sure there is enough pad left, 1/4" legal min. Your company should replace them sooner
  11. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    What a lot of BS and misinformation in this thread. Apparently many just read the title without reading the post.
    First thing, the brake pads need to be at least 1/4" thick measured at the center of the shoe. That means the top and the bottom of the drum.
    As far as the dust covers are concerned, some will have inspection holes in the top and bottom while others will be removable. I have not run into the removable type and most of our trailers do not have them anyhow.
    taxihacker66, lovesthedrive and baha Thank this.
