How to properly block (disconnect) one fuel tank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by vadim2200, Apr 23, 2014.
  1. vadim2200
    vadim2200 Light Load Member
    128
    36
    Nov 21, 2010
    I got hole in my pass. side fuel tank on KW T2000, can some one please tell me how to block this tank? Should i just unscrew 2 lines that go to the tank and connect them together? The reverse like and the one that pumps out fuel. But before i do this i still have fuel in it and I would like to use it. So should i just block the the line that pumps fuel back in the tank and let other one to suck out what ever is left?
  3. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    i would plug each hose vrs hooking them together. i had the same thing happen last year put a hole in a fuel tank and i removed the hoses going to the damaged tank from the t under the truck and installed some pipe plugs. ran for a few weeks on one fuel tank like that before i replaced the tank
  4. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    I'd plug them off like Ez said. You can pinch off the return line to that tank with vise grips for a little bit if you have a gauge on both tanks but don't let it suck air. It will transfer it to the other tank faster than you think. Harbor freight sells cheap pumps for 55g drums that will work for that also
