how to raise the fifth wheel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rodeo_Joe, Jan 25, 2010.
  1. Rodeo_Joe
    Rodeo_Joe Light Load Member
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    anyone know of a way to raise the fifth wheel on a 2004 Kenworth? trailer is low in the front an always hittin the plastic tire covers an breaks the fifth wheel airline cause it gets caught on it.
  3. broncrider
    broncrider Road Train Member
    are your air bags inflating?
  4. Coal Bucket
    Coal Bucket Light Load Member
    179
    74
    Nov 15, 2008
    Charm City
    Get model # off of fith wheel... in model # will be your current stand height... go to dealer or parts house that sell your brand fith wheel and order taller stands... there are usually many differnt height choices.... changing them out is not that hard, also makes the perfect time to rebuild your pivits if the need it.... I guessing your tractor was set up to pull high cube trailers and now your pullin trailers with tall suspensions and possibly tall rubber? not a hard fix....
    Rodeo_Joe Thanks this.
  5. Rodeo_Joe
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    oh yeah there full.
  6. Rodeo_Joe
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    Yeah that must be it cause the fifth wheel looks like its almost layin right on the frame rails its so low. I'll do exactly that! I'll order them up thank you!
  7. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    u must check the fifth wheel height ....bags inflated, fifth wheel level like when under a trailer ...height should be 48" max to the ground or you won't be able to haul a van ... then you can figure how much to raise it .... any good welder should be able to do it for a couple of hundred bucks
  8. Coal Bucket
    179
    74
    Nov 15, 2008
    Charm City
    yep 48" would be max for a van, but ive had a few taller than that, but only ever pulled dumps, flats and tanks.... its not that bad of a "do it yourself job" if its a slider the only welding needed would be for the stops at the back... gotta cut the welds and remove the bolt that holds it them in place (one each side), after reasembly they would need rewelded but that shouldn't cost to much for a couple of beads to be laid down ... If it is a fixed wheel then no welding at all, i would just torch the old bolts off and replace with new grade 8s course they should be replaced any how... I like to do as much as i can myself, but its definitly easier to have a shop do it for ya...BTW.. wasn't tryin to down play your advice 112 (cause it was right on) just sayin what i know from my own adventures...
