Hi all, I'm looking for tips on how to find a gear after I've missed it downshifting.. there have been times where I've struggled getting it in gear after missing it
How to recover from a miss shift downshifting
Discussion in 'Questions From New Drivers' started by BIGLEFTYINTX, Nov 19, 2018.
Page 1 of 6
The first key is ramping up the engine RPMs to roughly 1,500 rpm and making a rough guess which gear matches the current rolling speed and try and get it in once the rpm has ramped up. If that doesn’t work, recalculate and try again.
rabbiporkchop, Nothereoften, BUMBACLADWAR and 1 other person Thank this. -
The biggest problem in missing a downshift, is over revving for that next gear. If road speed is dropping fast, it may be just as easy to skip the next one, and go to the next. Remember, it's only a couple hundred rpms between gears. Make a quick glance at rpms, speed and gear that finally worked, as kind of a model for next time. Over revving the motor.
Shaggy, Long FLD and VIDEODROME Thank this. -
A lot of times after missing a gear you need to skip that gear and hit the next one. I used to chase a gear all the way down and always be one gear behind until I skipped a gear and bingo started hitting it perfect. It gets to just be a habit after a while
rabbiporkchop, Nothereoften and MartinFromBC Thank this. -
One trick is to write down the MPH for every gear. Another thing is look at you RPMs before downshifting. It's usually 400 RPMs between gears. So if your at 1200rpm add 400 you have to get 1600rpm to get it in grear
Each truck engine responds to a fuel tap and “accelerates” at different rates. When parked, tap the accelerator and see how it responds via the tachometer. Keep this response in mind as you tap to try and match the rpm to the gear you’re hoping works for textbook gear selection
Remember, you’re not going to get it into ANY gear at idle or near idle and the same for higher rpms over about 1600. When you find a gear, it needs to be one that “makes sense” at the present speed so you’re not lugging or over-speeding.Farmerbob1, BUMBACLADWAR and Shaggy Thank this. -
Going downgrade? Come back upstairs one or two, make it quick. And then gain control of the rpms using service brake until the jacobs have a hold of it. Usually downgrade when everything is in order you don't shift. Much. Hardly at all.BUMBACLADWAR, I glide 47 and Snailexpress Thank this.
You could get a sweet automatic like the DT-12. That way you would never miss a gear again. Hands at 10 and 2 focused like never before. A missed shift costs you time, fuel mileage, but most importantly humiliates the offender.
Not an issue witha DT-12. Confidence climbs, fuel mileage climbs, time is saved. Call it the triple win.x1Heavy, Long FLD and snowman_w900 Thank this. -
Mine (DT12) does my laundry while going down grades and cooks my meals when going up. Plus, it gets 13.5 mpg heavy and into the wind. But I don’t like the way it sometimes forgets to balance my checkbook every month. Still waiting for the flash update.Farmerbob1, x1Heavy, BUMBACLADWAR and 4 others Thank this.
best transmission? 13 speed. 2 transmissions in one.
Page 1 of 6
