How to remove bad smell from trailer?
Discussion in 'Ask An Owner Operator' started by george_spr, Apr 2, 2015.
  1. george_spr
    george_spr Bobtail Member
    15
    4
    Mar 24, 2014
    In October 2014 I had load with animal food on palettes. It smelled like fish. After removing the pallets It was wet where were the pallets.......and than the problem began. I had few loads rejected. Started to putting coffee before to go for pu. I used more coffee than Starbucks.I washed the trailer and gave the guy extra cash to put more soup or whatever they use. During the winter time I didn't have any problem. I assume the cold helped. Last week 85 in FL and my nightmare is back. So I'm looking for psychologist. Whatever. ...do you know any product or method I can use to remove the fishy small? I have wood floor. Thanks in advance.
  3. Lowa3468
    Lowa3468 Heavy Load Member
    889
    648
    Feb 10, 2014
    Portland, Or
    get you some vanilla extract and spread it over the area that should take care of the smell and works allot better than coffee
    also you can try using fabreeze on it and see if it will work also, as they show in the commercials about people being in cars with garbage in them and the people that are blindfolded don't know...
    those would be my best 2 tips for ya.....
    george_spr Thanks this.
  4. tow614
    tow614 Road Train Member
    3,759
    4,631
    Mar 18, 2013
    Another thing is charcoal....it absorbs all odors but to be honest i normally used coffee...would buy the cheap stuff at sams and spread it on the floor and sweep it around...always worked...
    PE_T and george_spr Thank this.
  5. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    try Odoban. I used to haul out of Degussa-Goldschmidt where they produce the dimethyl benzyl ammonium chlorate. the active ingredient. it can actually destroy odors, not just mask but it doesn't work on everything. I would try a quart in 5 gallons water, scrub with broom and let it air out. with a fan to help if possible. they sell gallons at some dollar stores.
  6. Lonesome
    Lonesome Mr. Sarcasm
    11,492
    23,764
    Dec 15, 2007
    Northern Indiana
    Haul a load of peppermint oil.....
  7. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Yep coffee grounds works great.I use to pick up peanuts every couple weeks and before that I would pick some product up that made the trailer smell horrible so I would use coffee grounds let it set for an hr sweep it out then leave the trailer doors open all night and pick up the peanuts the next day.
  8. MZdanowicz
    MZdanowicz Light Load Member
    221
    207
    Apr 7, 2013
    peabody, ma
    Mr.X and george_spr Thank this.
  9. BrenYoda883
    BrenYoda883 Road Train Member
    1,248
    1,422
    Sep 18, 2013
    Back when I pulled reefer we had a trailer that stank even after a few good washouts.. so what I did was bought a big bottle jug of white vinegar added it to a bucket of water.. and washed the floor with it.. then I put several boxes of baking soda in it... that worked.. the smell was finally gone...
    george_spr and MZdanowicz Thank this.
  10. CAT76
    CAT76 Bobtail Member
    21
    18
    Oct 1, 2014
    NC
    Tide washing powder is what I used after hauling oysters
  11. Frghter Century 12.7 Detr
    Frghter Century 12.7 Detr Light Load Member
    83
    27
    Mar 6, 2015
    That's correct! We haul Containers and we have to load empty cans of Coca Cola that goes to the Caribbean and that container cannot have any smell as that taste can get inside the empty cans of soda's that are filled over there and that's what it's used, Coffee and leave the doors open all night.
    pattyj and george_spr Thank this.
