How to remove peterbilt steering wheel 357
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2006gmcdmax, Mar 17, 2018.
take the horn button off, remove nut holding wheel to shaft, lift off. BUT a steering wheel puller may be needed. sometimes that can be rented out at Autozone, or NAPA?
but be forewarned too. many times, the steering wheel can be "indexed", meaning what you want to do, cannot be done, as THEN it'll be at a much different position. usually the best way to get the wheel straight is by adjusting the toe in/out.
place wheel at perfect straight line position, find a way to lock it there, (several bungee cords, maybe chained down) then make the toe adjustments.
i'd highly recommend an alignment shop.2006gmcdmax Thanks this. -
If you have an adjustable drag link, set your steering centre with that.
I figured it out wasn’t sure if the black piece on top unscrewed
buddyd157 Thanks this. -
