How to remove prostar wiper motor
Discussion in 'International Forum' started by 7seriestv, Feb 12, 2018.
  1. 7seriestv
    7seriestv Light Load Member
    230
    144
    Jan 28, 2016
    When I turn on the wiper the blades go up and stop on the windshield, have to push them back down. When I lift the wipers off the windshield they wipe about 4 times and stop on in the up position. I'm thinking it the motor.
    How do you remove the motor?
    I remove the main nut 13mm that holds the linkage, their's also about 3 t25 screws hold the motor to the bracket. I loosen them but the linkage still attached to the main bolt. What's the secret to remove it. It's a tight spot to work without removing the air filter box.
    Thanks in advance for any help
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Motor and linkage are complete assembly. Remove your wiper arms, remove the wiper cowl tray, then remove the linkage assembly from the firewall.
    Justrucking2, 7seriestv and Jazz1 Thank this.
  4. 7seriestv
    230
    144
    Jan 28, 2016
    I replaced the motor this morning, everything works good now. Their is a recall for the wiper motor on international prostar and lonestar 2007 to 2010. But I didn't have time and didn't want the dealer to hold on the the truck for days for a $130 repair. I brought the motor and install myself. Fairly easy job.
    Remove the air filter box
    Unplug the motor electrical plug
    Remove the 13 mm nut holding the linkage to the motor
    Remove the three T27 torx bolt holding the motor to the bracket
    Take out the motor
    Install the new one, simple
    Justrucking2, Heavyd and Jazz1 Thank this.
  5. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Also keep in mind your exterior door handle is plastic and can snap off, that was very disappointing.
    Justrucking2 and 7seriestv Thank this.
