How to remove Volvo armrests on 2018 780?
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Dec 8, 2018.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I never use them and they are oftentimes in the way. There is no visible attachment point. I have tried pulling them off with no luck. Can they be easily removed? The seats are stock in a 2018 780.
  3. sirjeff
    sirjeff Medium Load Member
    If yours is a national like mine, the arm rest is held in by a little push button on the tube that comes out of the arm rest and locks into the seat. You'll have to pry the seat foam and fabric wayyy in towards the middle of the seat to find it
    Midnightrider909 Thanks this.
  4. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    From my experience as a long time Volvo lover, they fall off by themselves after 4-5 years - at that time the chair needs replacement anyway.
    tommymonza and Midnightrider909 Thank this.
  5. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Put a seat cover over it, problem solved.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    How do you drive without using the armrests?
    86scotty Thanks this.
  7. TIMPTE 527
    TIMPTE 527 Medium Load Member
    608
    827
    May 28, 2018
    When I bought my truck the arm rests were in a plastic bag with all the manuals to the truck. They were never installed because there's no hole in the fabric on the side of the seat to slide that tube into. When I saw this post I thought great someone is going to explain how to get them out which will essentially tell me how to get them in.
    rolls canardly and 86scotty Thank this.
  8. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    They stick out and Make it harder to load/unload the truck and move from the sleeper to the seats.
  9. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    I usually keep both hands on the wheel and rest the left arm on the door sill. The right arm never seems to need resting.
    tommymonza Thanks this.
  10. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    I would make the dealer install them.
  11. Ridgeline
    22,453
    117,497
    Get something called a hacksaw.
    Problem solved,
    blairandgretchen Thanks this.
